0 Members and 38 Guests are viewing this topic.
AlienGrey
Wesley thanks for the information.
Bye the way I recently came across Mr Dall's web site I don't think Dally or however you want to spell it is his real name.
Дневник Edward_Lee (Dally)
x_name41
the idea here is to dilute impulsively  electrolytic capacitor on the "kacher" with with powerful short impulses in packs with a repetition rate of 50 Hz.  The "kacher" in turn forms on the secondary winding (as a resonator) a powerful electrostatic pulse field which effects rhythmically on the bifilar capacitor by charging it with intense charges whereby to obtain pulse amplification of the current
source: https://strannik-2.ru/index.php/forum/t-kapanazde/12-generatory-tarielya-kapanadze-obshchaya-tema?start=285#29939
http://energyscience.ru/post4524.html#p4524
AlienGrey
Thanks for the information it's certainly interesting idea, not sure the katcher primary or the mosfet would like 250v up it so to speak, and this system has no bifilar wingdings as such and the 10000uf at 500v cap would be a bit of a lethal beast . Interesting though.
many thanks Allen
stivep
This is a good approach.  the whole concept of that what what I call Electrostatic Pump Phenomena is to create electrostatic field "sucking" electrons from the ground  by use of ground wire.
Nature needs balance so any difference of potentials tends to  equalize  itself.
However electrons have  inertia.  the mass of electron flow can be measured by crossection of the ground wire . And that is why ground wire must be thick.
Well
SR did not use thick wire but there is assumption  that is quite straight forward.
Ignoring inertial motion is like ignoring fact that current is directly proportional to  density of electron flow.
So the higher  is density  the larger is mutual inertia of such flow.
The time between impulses is the time when such inertia does the work.
If now you place primary of the transformer on the path from ground wire to the electrostatic difference point( destination)
than the secondary of such transformer must induce   certain amount of usable power that can power the  resistive load such as light bulb.
That is part of information that I'm authorized to deliver  as this is my own experimentally proven fact.
But there is nothing  to prove here anyhow .
So what that you do not have  yet FE given on the table.
Just get to this point at least please.
The next is frequency and shape of the impulses.
Square shape is  not always good unless impulses are short or very short. ( amplitude is conserved but  width  is regulated)
The rising edge and falling edge are the AC components of DC  rectangular  impulse.
The frequency should not be  falling to the area of skin current . If you remember Tariel was using impulses that are so incredibly slow.Well. not slow. There where spikes with long intervals. ( aquarium1 and aquarium2)
When you get to skin  current  than you lose all of the advantage of thick wire.  https://en.wikipedia.org/wiki/Skin_effect
As far as me:
there is a plumber and there is a plumbing designer, the only third guy out there is Tariel or any other inventor( or invention  thief)( in Russia often such thief is also a murderer)
I'm not a plumber nor intend to be one. However all of them  are mutually important.
I'm also not an inventor. I was not lucky enough  but inventor does not have to be smart, sometime it is just luck.
Wesley
Sergh
Who so draws electrical circuits? The child is unable to attend school, so he does not have a ruler?
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg516513/#msg516513
There is a more interesting scheme of this type ..
Secret radio noise generator of "Russian hackers". uhaha
Works only with Soviet transistors KT610. Urgently buy everything. ;D
The Sample of correctly drawn electrical circuit:
