0 Members and 174 Guests are viewing this topic.
Belfior
Quote from: AlienGrey on February 13, 2018, 07:16:50 PM
Thanks for the information it's certainly interesting idea, not sure the katcher primary or the mosfet would like 250v up it so to speak, and this system has no bifilar wingdings as such and the 10000uf at 500v cap would be a bit of a lethal beast . Interesting though.
many thanks Allen
Maybe the "BIFILAR OUTPUT COILS" is a coax cable over the others?
Belfior
Quote from: Grumage on February 10, 2018, 07:34:45 AM
Dear AlienGrey.
I have read many times about this " closing a switch and killing the operator " ! An open question to you and all members....
Is this actual fact or just an old wives tale?
I ask because if actual fact it may provide a clue to what TH Moray was doing.
Cheers Graham.
I has been documented and witnessed many times. Workers connecting power to a "cold" system get turned into ashes by high voltage and current. Like the voltage gets into the system, but the current meets some resistance. Another way is to pull on a lever to disconnect a system and they get zapped. Witnesses say that there were white streamers over the cables and over the insulation. You can experiment with this by pulling a car ignition cable out while it is running. The back EMF is so strong it will give you a jolt even with all the insulation.
I read this in a book and trying to find which one it was
AlienGrey
Quote from: Sergh on February 14, 2018, 03:51:27 AM
Who so draws electrical circuits? The child is unable to attend school, so he does not have a ruler?
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg516513/#msg516513
There is a more interesting scheme of this type ..
Secret radio noise generator of "Russian hackers". uhaha
Works only with Soviet transistors KT610. Urgently buy everything. ;D
The Sample of correctly drawn electrical circuit:
Perhaps!
Coils L1, L2- 10 turns of 0.9 mm on a 6 mm gap. Transistors T1-T4 are located in a 30x30 mm square radiator 90X90X3 mm. The general cooling of the R1 and radiator mini-cooler R1.
Allen
AlienGrey
Quote from: Belfior on February 14, 2018, 04:11:00 AM
Maybe maybe not you could try winding the brade the other way he has it bucking as I was thinking the
the back end might need or needs a total re wind but the idea does add up. PWM
Allen
AlienGrey
Quote from: Belfior on February 14, 2018, 04:29:57 AM
It depends on your stored energy in the inductor LC doesn't it ? other wise PWM PSU's wouldn't work  ;D
Eric Dollard, that's how T Edison pissed off Tesla! Energy from the vacuum series try Dollard's web site.
https://www.youtube.com/watch?v=TttHkDRuyZw
