0 Members and 136 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on February 28, 2018, 05:21:20 PM
Is that the protection diode in the PSU? If so, the Peak inverse voltage (PIV) rating is likely not high enough to prevent HV spiking on your supply line possibly damaging your PSU. Those cheapo Chinese PSU's are commonly sold for LED lighting applications, so are not designed to power devices that generate high voltages.
look out for the spike milligan sort of a shock horror thing then. ;D ;D just put a ceramic cap across it i doubt any diode will survive thousands of volts like Tinsel was showing.
Kator01
AlienGrey,
you mentioned the fallen angle Mirin Dajo from Netherland. In the following vid ( in german ) there is a text at the end of the vid which I have translated for you. I stumbled on this vid years later when I learned of this guy.
Mirin Dajo - true name Arnold Henske
Name of his assistant ( handler ? ) unknown
Translation:
Kurt E.Koch ( *1913 - 1987 ) was an evangelical theologian and publicist
who was present at these performances in 1947/1948. He wrote in his bokk "Occult ABC ( meaning Occult
Basics) on this subject:
Both men were members of psychic circles in Netherland.
Both Dutchman have demonstrated this floret-stabbing in different countries about 500 times.
When they performed in Zürich ( Switzerland) and showed this experiment day after day some faithful
people became scared. I know that that some small prayer-groups were gathering asking god to finish
this cruelsome spectacle because they assumed daemonic powers acting in disguise.
So what happened ? At or after his 500 th experiment Mirin Dajo died. His Aorta was ruptured according to
the coroner ( this info is published in the german version of wikipedia)
This was the end of this cruel drama.
https://www.youtube.com/watch?v=3GEWAcSR_bo&t=198
See here what is written in wikipedia:
https://en.wikipedia.org/wiki/Mirin_Dajo
Mike
Kator01
wesley,
Quote "If any one of you is interested I will say more"
Yes wesley tell me more if you can
Mike
stivep
Quote from: Kator01 on February 28, 2018, 07:13:04 PM
wesley,
Mike
https://ru.wikipedia.org/wiki/%D0%90%D0%BF%D0%BF%D0%B0%D1%80%D0%B0%D1%82_%D1%81_%D0%B2%D0%B8%D1%85%D1%80%D0%B5%D0%B2%D1%8B%D0%BC_%D1%81%D0%BB%D0%BE%D0%B5%D0%BC_%D1%84%D0%B5%D1%80%D1%80%D0%BE%D0%BC%D0%B0%D0%B3%D0%BD%D0%B8%D1%82%D0%BD%D1%8B%D1%85_%D1%8D%D0%BB%D0%B5%D0%BC%D0%B5%D0%BD%D1%82%D0%BE%D0%B2
This is just  mill that allows to make fine  metal particles.
But this device allows  also to rust these particles
So now you have  glass container inside the tube and your rotational frequency  is much lower.
You pour water into the glass container  with metal powder in it.
In larger scale horizontally oriented    porcelain cylinders  are used.
Rust over the particle delivers high megaOhm  resitive coating  around the particle.
It is mine of money for someone who gets into this business.
After you dry these particles also using the same  device  that in video( very low rotation.) to centrifugal water  evaporation or by means of  use regular centrifugal force in regular centrifuge ( again low rotational speed)
You can use this powder to make ferrite pipe or any other shape.
In home  environment you can use flipped upside  down  mechanical jack or  pneumatic jack  or hydraulic jack used  to lift the car.. supported by the metal frame. You create  simple press.
Form used to  give desired shape to the Green State of the ferrite can be done from hard wood both the bottom and the  top of the form. Later on you can make form from  metal.
The pressure does not have to be  big. 500kg/cm is plenty more than needed.
The simple screw rotation  hand operational  press can be obtained for few  dollars  as nobody needs them any longer. 3 to 5tons is Ok That is about  not so heavy  machine( ~300kg)
To make the material  to hold together binding  compound is  added in about 1 to 2% of total mass. It looks like  thinner for the paint  and about the same consistency.  In early time they used   very light motor oil with wood varnish or light varnish.
Than you place  the green stage into your kitchen oven however  600 celsus would be the best.
If you decide to make ferrite pipe this is  extremely easy.
You take two pipes  put one into the other  and space between the two  fill with rusted soft iron particles.
Than you press it with the stamp that looks like  flat fat cylindrical ring, in the way so it  compresses the powder.
After that you free the bottom of the pipes. You  secure a outer pipe in the  vise
and use the same stamp to push  down the newly formed Green Stage out of the pipe.
Now you need to remove inner pipe from already formed Green Stage.
that can be done by  making  circular hole in the table. Placing  Green Stage on the table and pushing inner pipe down  into the  hole .
Now your Green Stage is ready for oven.
In the same way you can make magnets.
So where is big money?
My friends if you want to go easy?
like million dollars per year?
well custom neodymium.
no rusting is needed.
however temperature in oven, and  press compression is much much bigger.
(Not to much around 900 celsius)
Where you get  neodynium  particles?
You take  magnet on the stick and just pick it up  there is plenty of beaches and other areas where tons of it is for free.
Than you power them in any  mill does  not have to be the mill from  my video. https://www.youtube.com/watch?v=Hns-SYQ0AF0&t=1s
If you want to go more difficult way but  do what nobody does?
custom ferrites with  dose of dope (doping) ( Ferrite from TV set Rubin used by Akula and Ruslan.)
I hope I did not say to much. :)
And if you do it  than you going to wakeup in the world of sintering Please do not be surprised  https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwj_-YDgpcrZAhWI6YMKHaA7DtgQFgg5MAE&url=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FSintering&usg=AOvVaw14XxXjLmtf2IaXSa4nQ6IG
sintering : is yet another big  avenue and big money on the spot independently from  that what I was talking about.
good luck
Now:
how good money  it is?
How sure business it is?
If I say 100%  for the success I would not be much in error.
There are "idiots" and rich idiots
-The first one do not have money for their ideas nor even  any ideas. They are limited by lack of money and lack of ideas.
- the rich idiots can buy you, your ideas and you will be still an idiot because you sold yourself  for few bucks
The choice is yours.
Who you want to be? :)
Wesley
AlienGrey
I n the land i live the girls have a neat trick they live with each other, but have kids as a single, the Gov pays for everything Free so what they need to work for but the kids have problems meanness.
so if it gets really cold since we cant eat money we can always burn the stuff to keep warm.
