0 Members and 2567 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on March 21, 2018, 12:38:41 PM
I'm not aware that he has. Perhaps he can confirm this?
I thought T1000 said that, that type of device worked but replied only with another transmitting device active at the same time, that is all I can find, Why don't you ask Nick for him to confirm that statement ?
NickZ
   Wesley has already answered the question concerning Akula's second device, and had made a video about it.
   If he would like to reconfirm it, for you guys that don't remember, that's up to him.
   (7) Akula video17b. Business trip of Stepanov to Akula.- It works!! - YouTube
Hoppy
Quote from: NickZ on March 22, 2018, 09:39:06 AM
Thanks for posting that link which I had not seen. However, I would also say it works from the video evidence in that it lights bulbs, just like Ruslan and Kapanadze's devices but it does not follow that they are real genuine self-runners. That cannot of course be established from a video or even by Wesley unless he has the opportunity to carry out a detailed physical examination of the device in its working location.
NickZ
      That's better than no witness,  and that's good enough,  for me. It seams like he is being impartial.
I hope that he was not holding something back, that time. And telling only part of the truth.
apecore
Quote from: NickZ on March 22, 2018, 12:46:39 PM
Ok Nick,...  i agree....
The box is half full and not half empty.
Lets look at the vid
So let me help you to get out of the water    and start to find first the differences and or aspects we have reconized in the last vew years
As i can see the following things perhaps for certain:
1- Interrupting kacher .. why?...  because there are some boxes like Ruslan has.. the one in the middle is conneted to the kacher transistor/ fet....and the box has a connection to the box on the right ( the yoke "box")
2- Wesley mentioned the TV yoke..  (Russian)... these could be one with Cobalt... (something what Hoppy would tryout/ look at)
3- There is a extra winding between kacher secundairy and Grenade..  (looks like 2.5mm^2 wire)
4- PS...  seems a normal PC supply..  which in my opinion no special function has in case of missing link/ or magic
5- The Grenade looks like it is wound different then Ruslan's type because the L5L6 windings are equal in numbers Even L3L4 looks like that ( so not in wirelength)...  probally it is a fact that the grenade can be wound differently and is most important that it has a very low inductance in combination of bibilar wounded
6- The Push Pull setup is also same configuration as Ruslan has showed... therefore i asume that the snubber configuration ( as Ruslan also stated to be important) is present here also.......this would match up with the Russian cobalt TV yoke.
7- Unknown is the requenty relation between Yoke// Grenade// kacher...
8- Inductor seems to be longer then 10M...  probally half the length of the grenade wirelength
9- Ground cable connection goes into the Pus Pull box..  this is also different probally the "STAR"groundpoint is located in this push pull box?
10- Antenna and kacher primairy have a fixed wirelength ( kacher primairy is ajusted).. Antenna looks like same lenth as Ruslan's
11- Maybe Wesley knows what wire gauge kacher secundairy is used so approxemately we can guess its fres range...the length of the coil looks like 10- 12 cm as the grenade is close to 20cm...
Do you see more points in which there are learning / discover points?
Greetings
In my opinion there are two directions to look at..
1- the special Russian TV yoke   (Hoppy's Roadmap)
2- The kacher// grenade// antenna etc.  or in other words the charging of the grenade bt the kacher system ..  (Which T1000 has explained several times in last posts)
