0 Members and 536 Guests are viewing this topic.
forest
Keep in mind that Kapanadze used similar circuit in his aqua box device.
AlienGrey
Quote from: forest on March 24, 2018, 03:35:13 AM
I mean - how and what is causing transistor to open and close and in what sequence and moments. Tesla coil is driven by square generator, if Katcher is somehow auto-adjusting frequency then we have to know how or it's like wandering in big forest without compass
If your talking about the device in the fish tank in the garage, No it's not look again it's fed from that old tv tripler behind the Katcher coil into the spark plugs pair and into the secondary the thick winding of copper tube.
I would think it's more like a radiant spike than a useless square wave in this case any way are you so sure the Akula is wired up on a working device as Akula shows in his circuit diagrams ? I mean whats the point of modulating the Katcher with 20-30 odd khz ? just use an inducter and diode and capacitors like Vasmos has !
SeaMonkey
Quote from: Alien Grey
Well if your that much of an expert perhaps you would like to explain why
Akula's Ruslan device doesnt work ! and whats wrong so it can be corrected !
thank you !  :D
And I think you will find Tesla's first Tesla coil was a motor distributor driven ignition magneto type device.
His device works to the extent that it is capable
of working.  In order for the device to output any
"free energy" it must first be able to access some
source of "free energy" to tap into.  That of course
requires that the "source of free energy" be known
of and its characteristics well understood.
Until that obstacle is overcome there will not be
such a circuit that is either a self-runner or a
source of "Free Energy."  Which also means that
the circuit mentioned cannot be "corrected" until
such knowledge is acquired and the source of
Free Energy proven to exist.
Tesla did work to produce several versions of
improved Induction Coils (not to be confused
with the Tesla Coil) which were modifications
to the already existent Rhumkorff Induction Coil.
Induction Coils
Rhumkorff Coil
Induction Coil (Wiki)
Those are the types of coils which are used
to power spark plug ignition systems in
gasoline engines.
Hoppy
Quote from: SeaMonkey on March 24, 2018, 03:56:56 PM
Common sense indeed! I think its high time to give the bench a rest and reach a consensus on the most likely source of free fuel / energy.
AlienGrey
Quote from: Hoppy on March 24, 2018, 05:27:03 PM
Hmm! well that's NOT the answer in fact it's the sort of dry logic whit you would expect from Lenard Nimoy!  >:(  https://www.youtube.com/watch?v=dULOjT9GYdQ
All i can say is you haven't figured it out yet have you !
It's about making the most out of what you already have.
Both Ferrox and Air cores have considerable losses, So how did they get it to work ?
it's known as the  mushroom syndrome!
Kept in the dark and fed BS ;D
Lern how to understand Russian!
