0 Members and 410 Guests are viewing this topic.
itsu
Quote from: NickZ on April 26, 2018, 12:52:28 PM
  Itsu:
  Ok, thanks. I'll see what I can do.
But, that is what we need to resolve in order to be able to aline and tune both frequencies together.
It looks like it may not be possible without exact the harmonic frequencies, to keep the scope images steady.
Well Nick,
already your kacher running at 892.8Khz runs on the 32th harmonics of your grenade signal at 27.9Khz, so it probably needs a small adjustment to sync both.
itsu
Hoppy
Quote from: NickZ on April 26, 2018, 01:23:20 PM
   That movie gets better,  just hold on to your seat.
   It's going to be hard to decipher fact from fiction.
Can't wait for the next episode!  ;)
itsu
Quote from: TinselKoala on April 26, 2018, 02:26:38 PM
Actually this is one area where the old Tek analog scope is superior to the low-end DSO. The Tek has the capability to trigger on _both_ channels alternately, displaying stable waveforms for non-harmonically related signals. Set Vertical Mode to "BOTH" and "ALT" and the Trigger Source to INTERNAL -- VERT MODE.
On the DSO you can get "snapshots" of stable traces for both signals, although not live, by using the SINGLE SHOT sweep/trigger mode.
TK,
yes it will present a stable signal to both channels, but are they really "in sync" like Nick wants?
I think that that setting will ALTernate between both channels, but does not sync them, so you cannot make frequency adjustments as
the trigger will ALTernate between them, if you know what i mean.
Itsu
AlienGrey
Quote from: itsu on April 26, 2018, 02:50:22 PM
TK,
Itsu
What TK is telling you is simply this, you said your self your katcher is 'free' running, so how can you 'lock it' to anything ?
Does every one walk at the same speed ? what are you going to do throw an anchor at it  :D or make some control logic so you can control and  lock it ?
NickZ
   Sounds like Itsu is right, and so is TK, so I'll fire up the old Tek scope and give it a couple of good swift kicks, and see if it comes back to life, again. Sort of miss using it...
  As my simple kachers range is between 830KHz to 1.1MHz. What frequency in theory should I look for on the grenade's output signal to match the kacher's frequency. Instead of normally doing it the other way around.
Using ferrite in the kacher pipe can induce a lot of addition heating from and on the inside out.
For me the non ferrite kacher frequency is 1.1MHz.
AG: I did not say any thing about free running. I've cut the kacher's secondary coil many times looking for the best resonant match up. And can further control the frequency using ferrite in the PVC pipe. Not looking to lock onto any frequency, as different loads need different frequencies.
I am however looking to make a controllable kacher circuit, as well. To keep up with the Jones.
