0 Members and 138 Guests are viewing this topic.
itsu
There is a difference between optimum and maximum, but this question could only be answered by the designers of this contraption.
Itsu
AlienGrey
What are you all on about FHS  ;D ;D cut out the SG1 stuff and get your Katcher coil on the bench and find it's resonant frequencys or forget it. Do you know how to do that ? It's in one of Akulas vid's Don Smith also shows it and TK shows a CD74C4046 card that can show it but you need a Freq meter,
Come on get real.
( Nick is that the natural res frequency ?  892.8Khz it's a bit low if you wind the SG up and down are there any more ?
We then need to know the timing sequence!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
NickZ
Quote from: itsu on April 27, 2018, 04:30:50 AM
Nick,
in the past (this thread), figures like 50, 60 and 100th harmonics were named as optimum.
Itsu
  Itsu:  So, what do the matching numbers look like for 1.1MHz?  Not sure how to figure it.
  There is only one best frequency point on the induction circuit that allows for any interaction when matching up the Kacher to the induction circuit on my device. No other point results in the output being lit up brighter by the Kacher's interaction. Which mean no interaction is noticed. But, that single best point seems weak, compared to the results I obtained with the same grenade and Kacher set up but using the Mazilli driver, instead of the TL494/TC4420 driver.
  It looks like several of us have their Kacher running best at around 1MHz. Is that just a coinsidence?
  If I try to go to a higher Kacher frequency, by adjusting it's secondary coil, like to 1.85MHz, I loose some of the output from the Kacher, and the streamer is smaller. And there is much less output from the Kacher at 2.8MHz etz... almost nothing. Maybe a 1 mm spark, and practically no streamer to be seen.
  Using the lower wattage bulbs (60w), results having to adjust the TL494 to a  higher running frequency (27KHz), but, the 200w bulb(s) run best at around 13KHz, or lower.  However, my TL board can't go any lower than that, like to 5-10KHz, or so.
  Just letting you know what I observe on my set up, as a comparison.
AlienGrey
Quote from: NickZ on April 27, 2018, 08:21:22 AM
Itsu not trying to be funny but It means nothing as it's not your harmonics of your katcher !!
NickZ
Quote from: AlienGrey on April 27, 2018, 08:36:02 AM
  AG: And you've found something that you can actually show us, (which is not just your untested opinion), which means something?
   Neither Akula, Ruslan, Stalker, Adrian, nor anyone has ever shown how to properly tune the actual Kacher/grenade set up.
Nor will they show just how to do that, for a reason. So, it's up to those interested, to go through the ropes.
  Simply tuning for the highest amplitude, is NOT the right way to go. Maybe turning for the highest current output, might be better. I tune for the brightest bulb output, and for the best "optimum" gain and interaction. Which is not at maximum amplitude.
