0 Members and 128 Guests are viewing this topic.
NickZ
  Hoppy:
  Any wave form would be better than nothing. I know that it's supposed to be DC after the rectifier, but...
   apecore:
   0.1uf 2000v WIMA capacitor | eBay
   The 0.15uf 2000v wima caps are currently not available. But, one of the above or two in parallel will work. Why do you think that it won't? Please explain.
You mentioned, "The other rated WIMA 1000V will burn as they are all parallel connected..... Nick will find that out.."
   Ruslan normally uses two of the 0.47uf 2000v caps in parallel on most of his devices, for the induction circuit capacitors. Some guys use a 1uf microwave cap, instead. Like Akula did at first.
Remember that most videos show different inductor configurations. Such as the 1/4, or 1/2 size inductor, as well as different number of the WIMA caps. To help further tune their device.
Hoppy
Quote from: NickZ on April 27, 2018, 12:02:51 PM
  Hoppy:
All you will see is a fairly straight line (on DC coupling) with some HV spikes. Not much use to you other than to measure the voltage level.
NickZ
  Hoppy:
  That's about it.  No real help at all. The best scope probe location for me is on the smaller 0.1uf wima cap, just before the rectifier. As it doesn't interfere with the HV signal, as much.
Hoppy
Quote from: NickZ on April 27, 2018, 12:18:04 PM
  Hoppy:
  That's about it.  No real help at all. The best scope probe location for me is on the 0.1uf series wima cap, just before the rectifier. As it doesn't interfere with the HV signal, as much.
Nick,
The point Im making is that you cannot and should not see the full HV waveform after the FWBR. Its nothing to do with interference.
apecore
Quote from: Hoppy on April 27, 2018, 11:58:09 AM
You will need a lot of plates for that sized cap!
IMO its much more about disrupting the grenade waveform by the HV / HF Kacher waveform at a precise point and in a precise way. That' s not to say that harmonic resonant tuning is not required, rather that a combination of both is likely needed to show desired effect.
Indeed Hoppy,  i do think the same.
Well i'd tried a lot of things,...... but to make the HF/HV kacher wave (even the pulsed version) unipolair is not so easy.
The Antenna is acting as a capacitor and won t let some diodes f.i. eliminate the half wave.
So here some practical advise or options would be welcome to give it a try to.
