0 Members and 65 Guests are viewing this topic.
apecore
Quote from: Hoppy on April 29, 2018, 04:21:21 AM
Neither of us succeeded in achieving a self runner but trying certainly kept us off the streets! The nanopulser did fail to have much effect on the push-pull generated waveform but in hindsight I don't think we managed to create a powerful enough and properly reflected / standing wave in the co-ax given the requirement for a shorted termination. A heat sink was specified for mounting the toroid but I never noticed any appreciable temperature increase even without the heat sink.
I think it is not wise to repeat all steps made by Itsu has he shown in his vids.
I d like to proceed in keeping the concept but with different methods.
Looking at the nanopulser effect,...  it seems there is a need for more power?
On the other hand we have to define the effect which the nanopuls needs to perform...
I would think the first main effect would be the inflow of radiant energy, in which risetime/ fall time of the nanopuls would be a critical parameter......
Does the Duration of the nanopuls realy matter or would it be more the dV/dt?
What does this tell us about the velocity factor of coaxcable?.... does normalbifilar wire has a higher VF?
Second...  timing of the nanopuls.....  this is probally the same issue as with the kacher puls....
In general we are facing the same goals as with the kacher// grenade.
So mainly i would start on this part first...
But looking at the inflow of radiant energy,...do we need to disrupt a magnetic field (i.e. de inductor wave)?... or the L1 coil..  (on the former with the parallel cap)
I guess we need to try both and make also the strength of the magnetic wave by the inductor adjustable.
Any other suggestion for first approach?
Greetings
apecore
Do you mean by that the nanopuls duration has to be defined according coax wirelength and Velcity factor...   to ensure that the cut-off of the puls takes place when the wave reaches the end of the coax wire?
Hoppy
Good morning Apecore,
You raise good questions that quite honestly I cannot answer with any authority other than to outline my current understanding.
Insofar as Kacher / nanopulser pulse width and rise time, my undertanding is that the dv/dt is the most important factor, together with pulse amplitude.
apecore
Hoppy
Quote from: apecore on April 29, 2018, 05:10:12 AM
Basically yes. If you viewed the incident pulse on a scope, the reflected pulse will be returned by a short circuit termination at opposite polarity, such that at a given length of cable, only the incident pulse will be seen.
