0 Members and 169 Guests are viewing this topic.
apecore
Quote from: Hoppy on April 29, 2018, 06:08:01 AM
Basically yes. If you viewed the incident pulse on a scope, the reflected pulse will be returned by a short circuit termination at opposite polarity, such that at a given length of cable, only the incident pulse will be seen.
Ok clear.
So important is to tune the duration of the nanopuls in order to get that perfect standing wave.
In which the velocity factor of the wire would is not exact due its wire specification
The duration of the puls will be one of the main parameters.
For my understanding,... we want to creat a quarter wave insie the coax...  in order to get the highest amplitude at the end?
So exact wirelength is not more or less critical because we can adjust the puls duration.
Hoppy
Quote from: apecore on April 29, 2018, 06:23:58 AM
Yes, as I see it.
Edit: I should make it clear that although I favour the nanopulser over the Kacher as a means to meet the theoretical requirement for the operation of the Daly / Ruslan device as postulated by T1000 and others, I consider through my own experimentation, that the overall build, choice of component and circuitry of the Daly device does not fit the theoretical modus operandi.
apecore
Quote from: Hoppy on April 29, 2018, 07:06:46 AM
Yes, as I see it.
Hoppy,
I think that is a important observation.
As i believe it is most important to design each part as close to theoretical idea/calculation.
Deviations might be better to review by that.
I did sone post readings but its difficult to determine the end design as it bin posted in time..
Starting with the nanopulser and its power part.
Btw   i will distance myself also from kacher concept...there are to much unsolved items to be done in order to get the discharging running
AlienGrey
Why don't you try winding a katcher and putting it on the inside of the grenade, push comes to shove
the katcher and the nano pulse device have a lot in common, it has to be. Obviously you would have to tune it.
