0 Members and 89 Guests are viewing this topic.
AlienGrey
Quote from: apecore on April 30, 2018, 08:11:22 AM
Indeed,....as it builds up the maximum voltage for the Spark gap to fire.
So probally ( as a posibillity) therefore synchronized by the push pull primairy  (also on that torroid)
Also after a closer look..  the HV  from the flyback>> SG..  is connected to coax wire..  which is at top of the grenade (inductor winding)
perhaps, or perhaps not as demand would require for energy and a faster repetition rate, re the fish tank.
Also the grenate mostly has a flat bandwidth how are you running that to a harmonic or arn't you going to bother ?
apecore
Quote from: AlienGrey on April 30, 2018, 08:20:42 AM
Also in this latest setup..  there is again one WIMA cap probally connected as series cap in the inductor loop......  size looks like it is again a 0.47uF/ 2000V type.
This again... seems to me there is no critical inductor frequenty needed....  due the adjusting of the inductor coils induction is limited ..
Again..  main aspect (as i believe) is the disruptive collapsing of the magnetic field inside grenade// Inductor...  as what seems until now we did not accomplished with a kacher.
So harmonics......  perhaps it will bring a bit in case of finetuning but it is not a critical parameter
Hoppy
Like in the fish tank, I suspect harmonics have little to play in the operation of the device.
Hoppy
Quote from: apecore on April 30, 2018, 08:26:12 AM
Or might just be one of the two Royer osc output caps.
apecore
Quote from: Hoppy on April 30, 2018, 08:40:11 AM
Or might just be one of the two Royer osc caps.
Hmmm,.....
Royer oscilator does saturate the core being used...  or not?
This also goes into the "special"core material what can be used for current amplification..
So maybe another parameter in the setup.....
