0 Members and 71 Guests are viewing this topic.
Hoppy
Quote from: apecore on April 30, 2018, 08:53:35 AM
Hmmm,.....
Royer oscilator does saturate the core being used...  or not?
This also goes into the "special"core material what can be used for current amplification..
So maybe another parameter in the setup.....
Its probably a variant of the Royer osc that uses a capacitor across the output to form an LC resonant circuit to give a sine-wave output, rather than the square wave output from a Royer. This does not require a saturable transformer and is more commonly known as a Mazzilli.This is more likely because the Mazzilli could be supplying the grenade inductor with a sinusoidal waveform as well as to the flyback trafo primary, which will be producing HV pulses at the spark gap in synch with the sinus waveform. Timing of the HV pulses could then be spark gap / HV cap adjustable.
apecore
Quote from: Hoppy on April 30, 2018, 09:22:36 AM
So when we go in that direction,...
One cap is used to make the sinewave wich feeds the flypack transformer.
Timing of the spark gap would probally always on top of the sinewave... so it has its own synchrised loop?
I also see that the coax is connected to one side of the SG,.... also believing the coax is only one side connected like the antenna previous
I m also not sure if there is a inductor in place.....as i would asume its source (3turn coil)  would perfectly fit (and makes sense) on the same core as where the flyback is connected.
Because i only see two with cables goin or coming from the grenade...  the third one on the right is the ground connection
Also the coax coil seems to be two layer configured...10 turns approx.... which brings it at almost 5 meter length.
But the big mystery is ....  is there a inductor in place?
Hoppy
Quote from: apecore on April 30, 2018, 09:44:10 AM
See the addition to my post above.
apecore
Quote from: Hoppy on April 30, 2018, 09:49:17 AM
Yes Hoppy i see.....
Also..  after looking closely to the vid..  i do see some grey wire going into the grenade under the coax... @1.14.
This grey wire is also going to the torroid.
On the other hand also the grenade output wire ( i believe the one coming from the right (out of the grenade tubing) is also wound on the torroid.. (like the 28T in the akula version)
Maybe it is to tricky to compare all things to be seen with the conventional versions we seen till now.
NickZ
Quote from: Hoppy on April 30, 2018, 04:59:39 AM
Morning Apecore.
Yes, interesting changes from Ruslan with the flyback trafo and Kapanadze style wire spark gap. Lots of electronics in this one, some of which could well be eye candy. Without additional info, not much can be gained from this presentation. Understandably, Ruslan is not getting rave reviews to this video.
  Looks like most of it is just eye candy. That is probably another secret device that we won't be able to do anything with. Like Kapanadze's last one, but TK's last one can output a whole lot more. TK is not going backwards in output power on his last device.
  BTW: apecore, it looks like Stalker's video are showing the Kacher pulse form peak alining with the bottom (valley) of the sine wave, and not peaking at the top.
So, not at the top, nor before nor after the top of the wave form, but at the sine wave's bottom of the valley, instead. Several other guys are doing the same thing, as far as this Kacher/grenade syncronization goes.
