0 Members and 158 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on April 30, 2018, 03:50:44 PM
If the Data Base was managed correctly and sorted I wouldnt mind betting it would be possible to get it down to an indexed less than 200 pages of
useful related index.
Maybe but people have different opinions on what is and what is not useful.  ;)
forest
I believe katcher is used to interrupt HF by saturating ferromagnetic core at for example 50Hz repetition rate and at the same time gathering some ions from air which release electrons to the output coil providing necessary current for powering load.
If you read Richard Willis patent you will find that his method is useful only on charging bank of batteries or capacitors which means RF HF without current, so the free electron  source is needed.
It all looks closer and closer related to many other patents for example Edwin Gray, Plauson etc
Hoppy
Quote from: apecore on April 30, 2018, 01:36:57 PM
Also a observation is that the board  below left is not a own made board but some thing out of a excisting piece of electronics,............ it is as i can see not connected.
The upper left board with the yellow led (start to lite up after battery is connected)  and green led (lights) after the system is switched on....is for not clear what its functionality would be
Further i see some diode banks with the redwire as common rectifyer.
Also, look at the bottom LHS corner of the box at 2.35. The red and black 12V start wires can be seen disapearing under a big dollop of what looks like solidified glue from a hot glue gun. Other red and black wires can also be seen going to other parts of the device.
Sergh
 >:( Video from YouTube:
A well-known gentleman from Latvia sold the "Free Energy" device to this person in Lithuania for 5000 euros.
Device is not working. The buyer requires a refund. He suspects fraud and will apply to the court:
https://www.youtube.com/watch?v=YBeESbCx0fQ
apecore
Quote from: Hoppy on May 01, 2018, 11:37:13 AM
It looks to me that are the voltage rail wires.... 12V which would also go to the PS.
Btw,...  my first test with ignition coil driven by square wave from Yoke/ push pull
Below short vid running the spark gap
https://youtu.be/2IUNBfeSdt0
