0 Members and 432 Guests are viewing this topic.
AlienGrey
Quote from: apecore on May 03, 2018, 07:06:20 AM
AG,
I agree on your comment about the car ignition coil, as running it on 50 - 200hz would be nice also.
But i would need very large inductor series caps...
About your second explanation using a tesla coil...  i do not understand what you dit with it....  you used it instead of the ignition coil?
Could you explain a bit more?
Greetings
Hi Mr Apcore Tesla coil what do you mean what did I do with it  ;D do you mean trigger it with wave shape turn on and off
at correct time with a supper high speed high current driver and GA mos fet ?
apecore
Quote from: AlienGrey on May 03, 2018, 07:34:16 AM
Mr AG,
I don t know what you are doing al day long?
I hope you are not smoking weed all day...but i think you are the only one who can tell me what you did woth the tesla coil?
If i knew it i would not question about it.
Greetings
Ps smoking weed is not legal where you live.. or does it?
NickZ
   Hoppy:
   I don't believe that even with a controllable Kacher circuit, I will be able to see the wave forms the way that Stalker has shown it, below.  As there is only one horizontal control on the scope. So, it may not be possible to see both wave forms at the same time, such as is being shown, as Itsu has mentioned.
Plus, the two waves are not steady.
   I just wanted to try out Itsu's suggestions. But, trying for a steady signal to sync the device, does not seam to provide much if any additional output therefrom. However, there still may be something to tinker with using that approach.
  I am also looking into the most simplest Kacher circuit controller, but I'm not sure which one to replicate, yet.
Hoppy
Quote from: NickZ on May 03, 2018, 08:49:56 AM
   Hoppy:
   I don't believe that even with a controllable Kacher circuit, I will be able to see the wave forms the way that Stalker has shown it, below. Wouldn't they would have running on the  SAME frequency to look like that? And not the way they look in the picture below. As there is only one control on the scope. So, it's not possible to see both wave forms at the same time, such as is being shown. Plus, the two waves are not steady. Anyway, I don't seem to be getting anywhere with this type of tuning. I just wanted to test Itsu's suggestions. But, trying for a steady signal to sync the device, does not provide any additional output.
Nick,
This is all getting a bit tiresome! I'll repeat once more - you need a fully controllable pulsed Kacher driver. The squiggle you see, is the HF Kacher waveform in a pulse envelope. The pulse width is adjustable as needs to be the phase relationship with the inductor waveform, so as to position it relative to the inductor sinusoidal waveform.
T-1000
Quote from: Hoppy on May 03, 2018, 09:03:05 AM
Nick,
On that note, what happened to the modded akula katcher driver circuit I shared months ago? Catching up with that only now...?
And sorry about being bluntly straight to the point.
