0 Members and 89 Guests are viewing this topic.
Hoppy
Quote from: T-1000 on May 03, 2018, 09:15:42 AM
On that note, what happened to the modded akula katcher driver circuit I shared months ago? Catching up with that only now...?
And sorry about being bluntly straight to the point.
Good point. Probably got forgotten and buried in all the crap. Show Nick that one again.
NickZ
  Ok, Hoppy, I won't bother you any further. Don't want you to get too tired from all this, could be bad for your health.
  You don't seam to understand what I'm trying to say. That it's not possible, to obtain the same image as Stalker, even with a controllable Kacher.
   T-1000:  Which modded Akula Kacher driver? Can you refer me to it?
   Can I modify my existing Kacher to sync on the grenade current wave form? Such as Adrian was going to do when he took the pics of his simple kacher circuit running his self runner. Which later he was going to modify. But, did not show that change.
   You had mentioned something about adding a transistor to the Kacher circuit, and taking the pulse from the small current transformer. Remember?
  EDIT: Ok, thanks for the links, I'll check into it.
apecore
Quote from: NickZ on May 03, 2018, 09:34:51 AM
Ha Nick,
Your going to build your own interupter?
Greetings
AlienGrey
Quote from: Hoppy on May 03, 2018, 04:36:18 AM
You need the fully adjustable pulsed Kacher circuit to achieve the waveforms you need to see. This was explained to you many posts ago.
I question the need to harmonically synch the Kacher frequency with the grenade inductor frequency. My understanding of the theoretical requirement, is to produce a sharp pulse of HV (HV Kacher wave in pulse envelope) that 'shocks' the instructors resonant sinusoidal waveform at around its peak value.
WHAT ?  ;D ;D ;D ;D Your a joker unless you trigger it at the right place it's free running it has to be controlled.
If a Katcher is running at 2 mhz you apear to think its RF at 2 mhz wrong ! find its periodic time minus the katcher trigger width and use that !
