0 Members and 148 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on May 03, 2018, 09:25:03 AM
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg495304/#msg495304
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg513770/#msg513770
Arunus  ;) I made that circuit it doesn't work, not with those components, the FET's have far too much capacitance
and it's slowing the speed down so as to a stop Gate capacitance of those Old Fets is 2 or more nano farads each.
It needs some of the newer Supper Fast mesh devices or a re design. Sorry  8) 8)
I have got round it another way for tests, for now.
T-1000
Quote from: AlienGrey on May 03, 2018, 11:30:40 AM
and it's slowing the speed down so as to a stop Gate capacitance of those Old Fets is 2 or more nano secs each.
Not sure where you get it badly but Geo actually have it running.
The katcher transistor need similar voltage divider like from Ruslan katcher to get it running then attaching logic with power control on/off from mosfets do the rest. And the power-on time is on dead-time between push-pull transistors.
Cheers!
itsu
Quote from: NickZ on May 03, 2018, 08:49:56 AM
   Hoppy:
   I don't believe that even with a controllable Kacher circuit, I will be able to see the wave forms the way that Stalker has shown it, below.  As there is only one horizontal control on the scope. So, it may not be possible to see both wave forms at the same time, such as is being shown, as Itsu has mentioned.
Plus, the two waves are not steady.
  I just wanted to try out Itsu's suggestions. But, trying for a steady signal to sync the device, does not seam to provide much if any additional output therefrom. However, there still may be something to tinker with using that approach.
  I am also looking into the most simplest Kacher circuit controller, but I'm not sure which one to replicate, yet.
Nick,
what i envisioned does not work, not beyond the 11th harmonic (306.9 Khz if start with 27.9 Khz) or so.
After that the frequencies are almost impossible to stabilize, so no need to try any further.
I tried it using 2 different FG's, one at 27.9 Khz, the other starting from 2th harmonic up.
Itsu
NickZ
   OK, thanks Itsu. I know what you mean now. Just barking up the wrong tree, I guess.
But I still don't see how Stalker can get both circuits to show up like that. Regardless of how controllable his kacher is. Might be that it's not really a  live kacher signal, like you had mentioned.
   Thanks again.
   I'll continue the search.
AlienGrey
Quote from: T-1000 on May 03, 2018, 11:49:25 AM
The katcher transistor need similar voltage divider like from Ruslan katcher to get it running then attaching logic with power control on/off from Mos Fets do the rest. And the power-on time is on dead-time between push-pull transistors.
Cheers!
yes I found all that, I'm getting some real fast Fets with only 50 pf Gate Sauce capacitance but that will be a while yet I need to see if it works.
