0 Members and 553 Guests are viewing this topic.
Hoppy
Quote from: NickZ on May 03, 2018, 02:22:08 PM
But I still don't see how Stalker can get both circuits to show up like that. Regardless of how controllable his kacher is. Might be that it's not really a  live kacher signal, like you had mentioned.
Nick,
The only way to find out is to replicate Stalkers Kacher interruptor. What circuit did he use?
NickZ
Quote from: apecore on May 03, 2018, 11:07:38 AM
Ha Nick,
Your going to build your own interupter?
Greetings
   apecpore: Well, maybe. I would prefer to improve the kacher circuit that I already have running, to be able to operate from a CT to open and close the transistor gate. But, no one has answered my question, yet. Nor do I even have a diagram.
  Yours is still "TOP SECRET",  I guess.  And I'm looking for the simplest design. That does not use a spark gap to control it.
NickZ
Quote from: Hoppy on May 04, 2018, 07:31:01 AM
Nick,
   Good question, Hoppy. As he changes things all the time.
   But, there is NO way that the signal can look like that, in real time. That, I already know.
   IF I build a controllable Kacher circuit, it probably will be the type that Stalker has shown.
   I'm looking into building the simplest TL494/TC4420 to the same 5200 transistor, version. As I have those components, and am familiar with their connections and the way they work.
  Any help is welcome.
apecore
Quote from: NickZ on May 04, 2018, 09:56:40 AM
Well Nick,
I m using one of the normal interuptor circuits which are posted several times here on the forum.
But maybe you just have to google for your self and do some enginering based on experiments by yourself,...   instead of waiting that someone will drop the solution.
Kacher interupter is nt just a CT or something like that..  there is more to define regarding your needs/ goals according this subject.
I can say to you that every circuit has its own errors and needs to solve......  this is much more complex then just making a TL494 run,....  due you need to make the kacher signal synchronize with the inductor.
I would advise you to look in the files from Stalker..... he has a lot of schematics available related to this subject
But i can aslo say this..  i tried 2 or 3 interuptor different circuits... with all kind of "fish wave" adjustments...... even one whith a second wave at the end which is 180degrees out of phase so it kills the ringing almost directly....  driven the inductor loop in a PLL loop.
But no free lunch yet.
We only see some energy induced from the kacher into the grenade,....  same as Geo has now....  probally due he has a bigger kacher secundairy he is able to generate some more energy..  but i m not convinced yet that the "charging effect"of the grenade is substantional done by the interruptor
But its good you give it a try,..  maybe you hit the jackpot with this
Greetings
Hoppy
What's wrong with the circuit T1000 posted to you? That's quite basic. As he wrote: "The katcher transistor need similar voltage divider like from Ruslan katcher to get it running", so you have all you need and he also said that Geo is using this one and its operating OK.
EDIT: OK Nick, I see you answered this one in an earlier post I missed.
