0 Members and 303 Guests are viewing this topic.
Grumage
Quote from: Void on June 21, 2013, 07:33:25 AM
You're quite welcome Grum.   ;D
Dear Void.
Sincerest apologies... And thankyou for your post. :-[
I am so wrapped up with this new project I have a "one track mind" :)
Cheers Grum.
Void
Quote from: Grumage on June 21, 2013, 08:14:50 AM
Hi Grum. Was just funnin'. Keep us posted on your progress.
The Hendershot angle may hold promise.  :)
NickZ
   Grum;
   Can you tell me why you think that the aluminum liner on the inside of the big air core needs to be connected in parallel to the inner choke/capacitor coil.  The way that some of the diagrams are showing, the choke/cap coil is only connected to the small tuning capacitor, but not to the aluminum liner.
Also, let's say that the rectified 220v DC voltage is going to the yoke's 25 turn coil, and then how is it connected to the big air coil? As I understand it the air coil is only attached to ground at the bottom, and at the top to the bulbs, only, but then possibly then back to ground  to complete the circuit.  Anyway all these different ideas can be tried.
  I have made and mounted the 12 turn resonator coil, as well as a 12 turn feed-back coil, on top of the big air core, so I think that that part is ready to go.
  I'm thinking that maybe a Pc battery back up source may be used as the akula 7ah 12v battery, and as the inverter to 110v as well, and use only 110v incandescent bulbs, instead of the 220v bulbs as Akula uses.
  Let me know how you're getting along.  I'm just about ready to get back into continuing my build.
        NickZ
Grumage
Quote from: NickZ on June 21, 2013, 10:38:26 PM
   Grum;
        NickZ
Dear Nick and all.
I have been following the diagram posted below. You will note that the internal choke is only connected to the capacitor. This capacitor is what is lining the coil former.
I have started conducting the first of probably many tests!! And using only 12 Volts. First interesting point is that for my device, at around 12KHz on the 7 turn primary drive coil. My resonator ( choke and capacitor liner) was developing 400 V p/p at a frequency of 36 KHz!! In other words in it's own freewheel mode. This resonant point was found by varying the frequency of the drive circuit.
That is a far as I have got. I need to speak with T-1000 in order to procede to the next stage.
So dear Nick I cannot really explain what is going on, only that T-1000 said that a capacitor within a magnetic field will develop a charge on it's plates.
Cheers Grum.
NickZ
   Grum:
   Thanks for your reply.
   There is a lot of confusion with the workings of this device.
   As I understand it by looking at Hendershots generator diagram, he was showing a home made capacitor which was wound on its outside aluminum surface by a wire coil. So, it was this wire coil that was connected to the homemade capacitor.  The outside surface of his capacitor, was made of aluminum, which was what the wire coil was using as a former, and was all within a larger woven wire coil. But, his inner home made capacitor/wire coil set up was connected to iron transformer which was located outside of the big woven coil.
  The liner on the inside of the air coil, is not a capacitor.  Although it is able to pick up the field generated by the air core and resonator coil, by induction.
What Akula is showing connected to his choke is possibly a small cap for tuning of the choke frequency. At least that is how I see it.
  Are you able to light an incandescent bulb yet? If so, of what wattage?
        NickZ
