itsu
Nick,
the lowest screenshot in your latest post shows a 2SC5200 transistor, but i don't think its a simple transistor Kacher drive ciruit as you will also notice
the 3 fets, one P-channel, and 2 N-channel fets.
I think they are designed to burst pulse the transistor so the Kacher is kind of interrupted.
Its similar in design as an earlier Akula design, see diagram below.
so yes, there must be severall Stalker designed Kacher circuits, both with transistors and MOSFETs.
The upper screenshot one on your last post is the one from this Alexeyka guy which i linked earlier here:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg520957/#msg520957  the 2 pots are for pulse length and position i think and can be
seen as an interrupter setup.
Itsu
AlienGrey
Quote from: itsu on May 12, 2018, 12:10:14 PM
Nick,
Itsu
This PCB will do Akula circuit or the Stalker circuit if you select the right components
T-1000
I will repeat myself but where you see diodes from push-pull they both give logic "0" on dead-time between turning on and that is only one time when the katcher circuit is allowed to be ON.
As soon there is one of push-pull transistors going active the katcher transistor VT3 KT805A (2SC520) base is shorted to the minus by the bottom MOSFET. Which abruptly interrupts Tesla oscillations. And in the way akula tuned that part it is usually on the peak of amplitude after few initial pulses. Which are filtered after choke between top load and converted to the spike on antenna. Then abruptly stops air ionization process and allow ions still be attracted by inertia to grenade and make self-charge of capacity.
Cheers!
NickZ
  T-1000:
   Ok, thank's for the explanation. Have you heard from Geo?
   Itsu:  I found the right Stalker video that is showing the circuit with the three Fets, and the 5200 transistor Kacher driver. He shows the two parts diagrams, side by side, the push-pull circuit diagram, and the Kacher diagram that you had mentioned that you liked. It took me a while to find, as I didn't know what to look for, and that particular Kacher circuit doesn't look like the other ones, so it took me a while to find it.
   Let me know what you think.
   https://youtu.be/NGiBxuLgjrw
T-1000
Quote from: NickZ on May 13, 2018, 08:45:32 AM
  T-1000:
Last time I heard from him he was strugling with income and was busy on jobs. I left him voice message asking to catch up and will see if he will have a time to talk.
