0 Members and 532 Guests are viewing this topic.
GeoFusion
Hi all,
Quote from: AlienGrey on May 18, 2018, 07:32:50 AM
to find spin next time emptying sink or bath observe !
//Geo  Hi
Any chance you can scope the say  the frequency of your katcher if it was free running or it's pulse width ?
Also any chance you can scope the input winding of the grenade input winding and show it's frequency ?
This information would be a real help or message me, any help would be a great help.
Many thanks AG
NickZ
Geo:
  Good to hear that you're back on the bench.
  Do you have your set up working as it was before?  If so, I think that the next step is to connect it up to the proper feed back path, to see how well that part of it works, also. As it will probably change all the previous tuning efforts. In any case, that is an important step that you didn't get to on your last videos.
AG,
Yes, observe the spin, it's very important,
that won't be a problem, when I get the chance I will.
Below you will see the attachment of a scope shot using prob when tesla coil was opperating when manifestation was happening. see those peaks and the dead time? That's what we are after.
mines is not perfect yet but now I know what it needs to be and now imagine that with pulse train after.
Nick,
Oh yeah, has been a while. but the setup is the same on bench since last recordings.
the TL494 push-pull driver board, has a glitch that needs a fix be for continuing.
About feed back, well it's the last thing I worry about, It would be the easiest part.. but
what we need to achieve first is massive output when connecting load which does not affect the input readings.
About Kacher/Tesla
I was feeding primary 24VDC but i'm for sure higher voltage input should do the trick when in tune.
24VDC was giving nice harvest of backround energy as you saw to the 300W bulb.
Originally Akula's diagram shows how he fed about 60VDC+ to his primary.
so what we all saw on my recording was just a bit of the result of what should be manifesting at output.
Itsu  is spot on by telling about the voltage on the primary by using a DC to DC converter which stalker is using.
That makes the difference if it will properly synchronize. Is the element I am currently missing now for
the tuning I have currently.
Remember how Dniester had long arcs at his antenna? now imagine the input voltage ;)
btw, his first attempt and success was not done with simple kacher, it had the interrupter circuit with it onboard.
try this, The antenna as close as the thickness of your index finger on grenade.
here you  can see what my prob was getting when in operation since that last video.
Cheerz~
AlienGrey
Hi Geo I'm not sure what that is at the moment, just got up but thanks I will try to sort it out in  my head later ;)
One experiment I have had trouble with is the tuning and how the grenade works, what I have done is I have wound another coil
in resonance you could say with the resonant frequency 'peek' amplitude of my grenade main coil (half it's length) that way I can load it
as Dally did not sure of it's harmonic though but i is most probably an odd number on a smaller tube and inserted it in side the 50cm main tube. I did ask Itsu but I think he had moved on or whatever, he said he had made a video or two a while back but didn't seam all that interested.
My point is if your grenade peek response is say 1500 khz and you used the 10th harmonic
you would be down to 150 khz you would then need to set up your push pull arrangement to detune 1500 khz to a much lower frequency.
The problem is what harmonic freq to use but you can experiment here with this just add on the above mentioned  coil all you need is a scope and a signal generator and look for the most current gain in your experiments by altering the tuning capacitor of the added coil compared to the 1500kz input on the inductor winding.
If you choose a harmonic like 25000 you get 60hz but it's far too far out of range the peek would be far too narrow to lock.
To setup the grenade find Itsu's video or  Mr Stalker explains in his video Nick talked about. Don't forget to add a real Earth to the main grenade winding.
Have fun experimenting !
AG
itsu
Quote from: AlienGrey on May 18, 2018, 06:42:29 PM
Hi Itsu you referred to a collection of videos on testing the capabilities of the grenade coil I had a quick look an hour or so and I cant find it any chance you can send me a pointer please.
Also  i found this the dally device In the video I cant seem to see the tuning capacitor i was wondering what value you used or freqency you tuned it to I did find some data where the device runs at 100khz approx not sure if that's true or BS.
Here is a video on Harmonics that are related to this problem.
https://www.youtube.com/watch?v=RUpjYDteYcg
AG
AG,
here some video's about me testing a grenade for frequency response etc:
https://www.youtube.com/watch?v=2G_nFy4zIek
https://www.youtube.com/watch?v=C4kz3qf0lns
https://www.youtube.com/watch?v=gMLgvSw-omg
https://www.youtube.com/watch?v=_-4RjDt29zA
concerning the Dally setup, i do not remember any variable capacitor being in there.
We had a L2 coil which was only a parallel LC consisting of a coil and a fixed cap resonating around 5khz, see those video's:
https://www.youtube.com/watch?v=MQUciCy9p3A
https://www.youtube.com/watch?v=utkIltw6WrU      L2 = 5khz
i hope his is what you are looking for.
Itsu
itsu
Looking at the screenshot from Geo, i see that his kacher runs at about 800Khz (5 periods in about 6us)
Itsu
AlienGrey
Quote from: itsu on May 19, 2018, 06:23:18 AM
AG,
Itsu
Itsu thanks for the list I will watch them later on.
Re the 5k paralell filter, I have come across that or some thing like it before but to be honest that LC would only let 5khz through every thing else would tail off, and the caps look a bit large for 5khz  8)
Re variable caps err alas no such thing here unless you have a switch box (expensive) no I just add or subtract caps till I find it  ;D
So was Dally 100khz - down to 5khz ? that would be in blocks of 20 (harmonics) ? did you get anything at that 5 khz frequency ? assuming he had peek energy at 100khz if you see how my mind is working here  ;D
My model grenade is happy at 1140khz , being dead on 100khz for Dally (what a coincidence ?? wouldn't that change, some place else ?
If you have any other ideas feel free.
AG
