0 Members and 124 Guests are viewing this topic.
itsu
AG,
according to the Dally diagram (see first few pages of this thread), the L2 LC parallel filter, as you call it, has a capacitor of 1.5uF.
I was initially using 600nF to reach 5Khz, but lateron switched to a 1uF cap to get to the required 4.6Khz, see this post:
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg337970/#msg337970
So i have no idea why you say that the caps look a bit large for 5Khz,  they don't.
Dally was using about 4.6Khz, no idea where you pull that 100Khz from, so indeed this tells me much about how your mind is working,  not (it tells me nothing i mean with that).
The nano-pulser i build was barely able to operate at 10Khz, and neither was Dally's nano-pulser, so operating at 100Khz is out of the question.
Dally was not using something what we now call a Grenade, unless you call his coil combo also a grenade.
Itsu
T-1000
Quote from: itsu on May 19, 2018, 11:42:22 AM
Itsu
Hi itsu,
In Dallly case the pulser repetetive rate was not high but the pulse width is what you would need to consider. It is very narrow in nanosecond range due avalance effect created in diode there. And this is enough to create same effect we have with Tesla+interrupter+filter choke. Just on much less output power.
Cheers!
itsu
Yes, i know, so therefor the frequency of Dally's setup was not in the 100Khz range, it was set at 4.6Khz, and this was matched by the nano-pulser repetition rate to have
each top of the sine wave interrupted.
Itsu
AlienGrey
Quote from: itsu on May 19, 2018, 01:28:30 PM
Itsu
Itsu forget about the Dally device and it's running frequency I needed the information as a referance in my experiments, so thanks ;)
My experiment on the Grenade
I had needed another winding on the grenade to test, I had some 45mm tube wound it with the recommended turns 1/2 length of grenade wire  and put 1uf across ends (as per your Dally test) and find the rather large  peek approx 1.28 mhz it  then drops in amplitude to naff all but picks up again at 700khz down to 93 khz it remains flat and then tails off as useless as it has no second peek.
WE ARE LOOKING FOR A SECOND PEEK! it depends on the capacitor size !!
you need to take this test/experiment on board.
AG
AlienGrey
