0 Members and 55 Guests are viewing this topic.
NickZ
  Grum:
  I imagine, the bulb will only light dimly, as the 220v AC after the rectifier is only 1/2 of the 220v, or about 110v DC, or so.  Right?
  The Al liner will play more of a role when higher voltages are used, like when I'm giving the yoke 1500v direct from the Joule Ringer circuit, the liner will induce some juice to the big air coil and will light some light a bulb, but not as bright as just with the Ringer circuit by itself.
   How 'bout a pic or two of your set up, sometime???
        Nick
Сергей В.
Привет всем
Hi Grumage
Hunt and read this article Tesla versus Illuminati Cabal Einstein - It disclose Aetheric Conversion Principle - Key to the Aetheric Energy is "Pulsing Сoncentric Сapacitor". (with proper dielectric !!)
Quote Harold. Aspden
"I have been prompted to write this by Don Kelly's communication concerning Tesla and this is my answer.  Whether this inspires those with the resources to research the
subject further, only time will tell, but, to be sure, there is so much money being spent building high energy particle colliders to probe the secrets of creation on Big Bang theory,
that one might hope that a little governmental funding could be spared to explore this 'free energy' theme.  It is founded on aether spin which itself already accounts for many features pertaining to the creation of the solar system.  Big Bang research can only lead to taking risks that bring about destruction and take us no nearer to the technology that can one day tap aether energy.  Tesla, it seems, achieved that objective, but we prefer in this year 2005 to celebrate Einstein, who blocked the way forward on the aether energy front, whereas Tesla is more deserving.  Hopefully, by 2031, the centenary anniversary of his Pierce-Arrow car, our scientists will be wiser on this question of the aether and its energy resource."
Also check newest Akula0083 schematic - from his last video with horizontal coils
http://www.freenergy.su/index.php?app=core&module=attach&section=attach&attach_id=2034
Hi Itsu
Lower Rds with many parallel high conductivity high voltage MOSFETs or IGBTs and than do the Coil Shorting on the peaks. The main goal here is Hypersaturation of shorting coil. Aviso used six bifilar windings in his reactor coil. Maybe even more. Also cut the intristic parasite diode with external high speed recovery diodes. Must be HV type and great number in parallel. Use HV filter to prevent demage from HV spikes on the input of your transistors. Use big cooler and conect transistors pins with wide oxigen free copper strip.
All capacitors for collecting OЭДС (back kick pulses) must be disconected from your Shorting Coil by High Voltage High Amerage Fast Recovery Diodes. The Capacitor ESR is a killer of OU effect. If you succeed in geting high amplitude ОЭДС pulses you can try multyshort bursts on the peaks like Aviso did, and many others. Takein account energy gain rise exponentially so you could get amplification factor of 100000 from just couple of shorting bursts. Main problem here is how to protect switching components. Or maybe inventing some new High Voltage High Amperage switchers.
For PeaktoPeak detector, scale down input voltage from your transformer on appropriate levels (to avoid clipping the peaks) on the inputs of TL084. You can use resistive or capacitive deviders or both (capacitively compensated resistive deviders like for example in Oscillographs). You can control tiny variations of your peak-peak detector using high speed shotky diodes and lowering integration capacitors value. Also you can control the level of feedback voltage adjusting multiturn potentiometers and resistors in feedback path. If you want precise timing on the outputs use monostabile multivibrators with schmitt triggers for example SN74121 or similar. If you haven't success after all of these modifications come back on the mechanical interrupters to catch OU effect. Also you can do some experiments to change the water clusters structured. The water have great number of different clusters and also have specific kind of nonorganic memory. One of components of Eternal Life. Another one is Electricity.... and so....
Book for you:
Applying Power MOSFETs to the Design of Electronic and Electro-Optic Instrumentation
Grumage
Quote from: Сергей В. on June 24, 2013, 09:39:46 AM
Dear Sergey.
Many thanks for your interesting post. Unfortunately it will not allow me access, perhaps you could do the honour, and post it for us all.
Cheers Grum.
Сергей В.
Привет Grumage
I have checked. Site is OK, you should wait some time until moderators don't approve your registration data. Maybe couple of hours or couple of days. After that you can post on new Akula forum. Maybe you need new Russian email on our Yandex Search Engine.
Register here and you will got new email and 10Gb Mail Disk for your data.
https://passport.yandex.ru/passport?mode=simplereg&msg=mail&require_hint=1&retpath=http%3A%2F%2Fmail.yandex.ru%2F%3Forigin%3Dhostroot_ru_nol&origin=hostroot_ru_nol
Also check Yandex Search Engine here
http://www.yandex.ru
http://www.freenergy.su/forum/4-osnovnoi
I found. People from our Realstrannik forum have uploaded new Akula schematic on this thread
Here is
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/129332-ustanovka-akuly-povtorenie.html?start=198#136514
post #136514
and probably block sch. with pulsing cylindrical capacitor at next picture.
Grumage
Dear Sergey.
Many thanks for your prompt responce to my request for information. We now have another one to look into!!
Dear all.
"Upping the ante"......... Earlier on I decided to try a low voltage input to the test rig, starting with 35 V AC onto the bridge rectifier. With 3 X 60 and 1 X 40 Watt incadescent lamps as load. As yet I do not have a "fool proof"  method of power measurement but initial tests looked good. With a fair brightness to the bulbs and a current of 1.75 amps. I next tried a 70 V AC input and a good light with less current was seen. Then disaster, bringing the frequency down a bit lower than 12 KHz, a massive bang and a fried IGBT and driver gone west!! How many units of electricity would that have bought??
Replacements ordered and also a Variac from Ebay will help put me back on track later this week. I did not want to apply over 300 V AC from the off. A slow build up IMO is the best option.
Dear Nick and Hoppy.
Below is my new home.... I found it by opening a door and clearing out the accumulated rubbish of eons :) Our kitchen is now a kitchen again and I have got somewhere to hide!!
For Hoppy, you will notice the obligatory trip and electrocution areas. And also, the now common dangling wires!! :) :)
Best wishes to all, Grum.
