0 Members and 58 Guests are viewing this topic.
AlienGrey
Quote from: Thaelin on May 31, 2018, 11:43:59 AM
This so reminds me of the old game, I've got something and you don't.  Colin Powell had a saying that rings so true, to bad it can't flourish here abouts. That is, " There is no limit to the good we can do if we are not worried about who gets the credit".
Think maybe?
thay
i wonder who he got it off  ;D ;D
itsu
Thanks Guys,
Nick, thats the correct diagram, i too found it this afternoon, its quickly presented inbetween some other diagrams in Stalkers video.
Its kind of raw, so i used a IR2113 setup the same as the one in the big diagram (modules 1 and 2) and a TC4093.
After some fiddling it does show the burst pulses as in Stalkers video, but its a differen module, so i call it module 4.
I will shoot a video later.
So we have:
module 1 (TL490 with TC4093) to drive (and delay) the push-pull MOSFETs
module 2 (2x TC4093) to take one of the TL494 signals and generate a short adjustable downward pulse
module 3 (3fets circuit) to manipulate the module 2 pulse (BE AWARE this pulse needs to be inverted (upwards pulse)
                for to drive the 2SC5200 Kacher transistor (no multiple pulses).
module 4 (IR2113, TC4093, MOSFET driver) to manipulate the module 2 pulse (using its normal downward pulse)
                for to create multiple short pulses to drive A KACHER MOSFET, SO NOT THE TRANSISTOR (due to the MOSFET driver chip!!).                https://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg520957/#msg520957
The only problem i have is with module 3 as i don't know what the output signal (which sets the transistor base)
should look like, more to show in the video lateron.
Regards Itsu
AlienGrey
Boy you like to make things complicated  ;D
Have a look at this it's doing the same thing.
itsu
Here a video about the signals i get from first the module 4 (pulsed MOSFET Kacher), and  the module 3
which is the 3 fets Transistor kacher drive module.
The problem i have is with the module 3 and specific about how the signal on the base of the transistor suppose
to look like.
I put up a screenshot below of that output signal slightly larger then what was shown in the video.
Yellow is one of the TL494 output signals (33%)
Blue is the module 2 output signal (negative going signal)
green is the module 3 input signal (pin 11 instead of pin 10 on the last 4093 chip) being the required positive going pulse
purple is the output of the module 3 at where the base of the 2SC5200 Kacher transistor suppose to be.
All modules are powered by a single 12V battery
https://www.youtube.com/watch?v=SQn-8hZSGhk
I just now see in Nick's last post his second diagram which explains the signals of the 3 fets circuit.
Need to take a closer look to that as its not what my purple signal shows.
Itsu
AlienGrey
Itsu Hi
Nice build not sure that purple drive signal is all that brilliant as it has a huge capacitance charge build up
for the output transistor in short it needs some sort of correction, I have the Arunus Akula board that too has
a lot of capacitance from the MosFets. To be honest unless the problems are sorted out whats the point.
I will connect my board up and see what that's like, but wasn't too impressed at the time.
AG
