0 Members and 136 Guests are viewing this topic.
itsu
OK, i studied the diagram Nick linked to above, see diagram below, and i think i have the correct signals
for driving the 2sc5200 transistor see the red circle in which the left part (darkend) looks like my
base signal (purple) in the screenshot i linked in my last post.
So i hooked up a 2SC5200 transistor and a kacher and drove it with 12V on the primary / collector.
The resulting signals are shown in the below screenshot:
yellow: TL494 signal (1 channel)
blue:   output from module 2 (2x TC4093) going into the module 3 (3 fets circuit)
purple: signal on the base of the 2SC5200 transistor (so somewhat distorted, see earlier screenshot)
green:  signal from the kacher via probe near to the top of the kacher (not connected).
Itsu
NickZ
   Itsu:   Looks like you've done it.  Lots of hard work and time went into it.
And it looks like the fish form, as well.
   Can the green signal be reduced into an abrupt triple burst pulse?
   Interesting how both T1 and T3 meet at the transistor base, and both pulse the kacher's base.
Who would of thought of that.    Great going Itsu.
T-1000
Quote from: itsu on June 01, 2018, 04:21:34 PM
Nice one itsu!
Now as you have that the free oscillations of Tesla coil have to be short circuitted to make spike out of it. This is where shorting base of katcher transistor and the choke between top load become very important. The choke have to be filtering free oscillatins and making spike burst in series on top load. Which will add up voltage to the existing output from the Tesla coil. Just be aware, the correct operation is making EMP bubble around and ionization which will cause ozone smell. The excited ions then should be picked up on bucking coil / grenade which is middle inductive plate between Tesla top load ("antenna") and other inductive plate to the ground of three plate open-air capacitor. The effect you are after is similar to the secondary electron emission in vacuum tubes.
Cheers!
NickZ
   T-1000:   Just how is the short circuit of the kacher signal done.?
NickZ
Quote from: T-1000 on June 01, 2018, 05:32:21 PM
Nice one itsu!
    T-1000:    I believe that the interuptor Kacher circuit that Itsu is working on already has the abrupt bursts at the right timing. Then nothing, and then another burst. All bursts at the same time frame as the induction circuit. 15KHz, or so.  Such as the image below.Yet, that will not change the free running frequency 1.1MHz that the Kacher's output at the antenna is running at.  If I am understanding what is expected, once the induction circuit is also brought into play.  The idea is that the signals should aline, and should look something like this.
