0 Members and 269 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on June 01, 2018, 05:32:21 PM
Nice one itsu!
Now as you have that the free oscillations of Tesla coil have to be short circuitted to make spike out of it. This is where shorting base of katcher transistor and the choke between top load become very important. The choke have to be filtering free oscillatins and making spike burst in series on top load. Which will add up voltage to the existing output from the Tesla coil. Just be aware, the correct operation is making EMP bubble around and ionization which will cause ozone smell. The excited ions then should be picked up on bucking coil / grenade which is middle inductive plate between Tesla top load ("antenna") and other inductive plate to the ground of three plate open-air capacitor. The effect you are after is similar to the secondary electron emission in vacuum tubes.
Cheers!
T1000  I don't think your circuit is capable of doing that, at least the circuit i have doesn't shut off the output device in the middle and then turn it back on.
AG
NickZ
  Nor do I think that Geo's new Kacher circuit was showing a short circuit type of operation, on his video.Nor was it a DC pulse output from the HV, that I could see. Please correct me if I'm wrong.
   BTW: Is Geo lost in space, again...   Common Geo... take the dust and cobwebs off of the thing, and fire it up.
And, show us how well that new Kacher circuit can work with the induction circuits. Please...
itsu
QuoteItsu:   Looks like you've done it.  Lots of hard work and time went into it.
And it looks like the fish form, as well.
   Can the green signal be reduced into an abrupt triple burst pulse?
   Interesting how both T1 and T3 meet at the transistor base, and both pulse the kacher's base.
Who would of thought of that.    Great going Itsu.
Nick,
in the diagram with the red circle above, you see that T1 is shorting the base of the 2SC5200 transistor to ground
about half way into the pulse delivered by T3, so its effectively cutoff (see purple trace).
But as you can see in the green trace, this will not immediately cutoff the free running Kacher signal,
instead it keeps on ringing down (fishform).
This ringing down like signal i have seen also in Stalkers video, so i think he is using a different circuit, or
an addition to this circuit to create these "triple burst pulse" signals you show in your screenshot.  Do you know from which video that screenshot you showed above comes from??
I yet have no idea how to produce such a "triple burst pulse", but i think T1000 is suggesting something in his post,
but i do not quite see what he means yet.
QuoteNice one itsu!
Cheers!
T1000,
i do have the "shorting base of katcher transistor" active, see T3, but what do you mean by "the choke between top load"?
Is it the ferrite bar with the 2 4turn bucking coils inbetween the Kacher and the antenna?
At the moment i only have a simple kacher coil attached, so without a choke or antenna, but i doubt that adding those
items will create a different kacher signal.
Also it runs on 12V only at the moment, so no streamers nor ozone.
Itsu
apecore
Itsu,
Yes thats the difficulty,....  to get rid of the ringdown signal.
T-1000 is theoretical correct using the choke principle...  nut in practise it is not that easy.
In the picture below you can see that the "BASE" signal is cut-off after the puls envelope is stopped....  the ringdown appears.
I d tried several ferrite combinations and windings... even diodes..
Just by shortcutting the BASE of the kacher transistor will not stop the ringdown
This is i think the most difficult but also the most important part of the deal.
Greetings
T-1000
Quote from: itsu on June 02, 2018, 05:22:21 AM
T1000,
Itsu
One of additions I did with Geo was making negative voltage offset to katcher transistor. By simply adding shotky diode between emitter and ground that made great difference on the output.
The part about choke filtering out front and back of free oscillations then releasing energy as series spike voltage add-up came directly from akula explanation in private conversations about 2 years ago. He had that in devices he made.
