0 Members and 184 Guests are viewing this topic.
itsu
I added a Schottky diode in the 2SC5200 emitter line, but this made very little difference.
The kacher output went somewhat down (5% or so), but still the ringing was there.
So i need to setup the original kacher with the choke and antenna etc. to see if that will make more difference.
For now i installed the module 4 (MOSFET driver with pulsed output) and added an IRFP460 MOSFET to the kacher coil
instead of the 2SC5200 transistor.
The signal can be seen in below screenshot 1:
yellow: TL494 signal (1 channel)
blue:   output of module 2 (input to module 4)
purple: output of module 4 (pulsed signal to gate of the MOSFET)
green:  output of kacher with probe hanging next to top (not connected)
I again have only 12V on the primary kacher coil / Drain MOSFET.
So it shows that also this pulsed signal causes the Kacher to ringdown for some time.
The 2th screenshot is zoomed in on the kacher signal.
Itsu
apecore
Quote from: itsu on June 02, 2018, 04:04:32 PM
Itsu
Good evening Itsu,
Something is not right,.   the signal from the kacher is not a nice sinewave.
Greetings
itsu
Ape,
I noticed that too, something is interferring, at least on the first part, as the ringdown part seems to be OK.
Could be my messy kacher coil i am using now, the breadboard setup or the low 12V kacher driving voltage, etc.
Itsu
AlienGrey
Itsu in your oscillographs you show only one TL494 output , can you display them both ?
you will then have a dead zone in between them can you then move /reposition your
katcher on pulses to the middle of the dead zone and re try to see if any difference.
AG
itsu
Alien,
i could do that, but i don't think that would be usefull as according to Stalker this is where the pulses should
be positioned, and secondly i can "move" the push-pull sine wave to any position via the TC4093 chip behind the
tl494 (driving the push-pull MOSFETs).
With Other Words, the moving /repositioning is not done by the 2x TC4093 module pots, but by the TC4093 chip/pots
directly behind the TL494 driving the MOSFETs
Itsu
