0 Members and 145 Guests are viewing this topic.
AlienGrey
I hate to say it BUT It's NOT snap on SNAP  'OFF'!  ???  8)
Have you ever seen a UFO disclosure clip of a McDonnell Douglas F-4 Phantom jet being circled by an ORB circling the Phantom at
phenomenon speed while the jet is traveling 'supper sonic' ? Well you have the same problem here ! ;D ;D ;D ;D
https://www.youtube.com/watch?v=yQleBmWbnJY
How the hell are you going to speed things up when the with those old MOS-Fets your using they are a joke after the HC chips.
It's the Gate Sauce capacitance !
AG
NickZ
   Itsu:   Ok, well it looks like you have produced the same signals are what Stalker is showing. I believe he compresses the signal (on the scope) to obtain what looks like a sharper peak with not much ringing. I saw how he did that on one of his videos.
I'll look for that, again.
   I wonder if some type of snubber added onto the IRF4905 or the other fets, would help to reduce the ringing. Some type of snubber cap and resistor. Apecore had suggestion something earlier, but I don't remember all the details right now. Perhaps check his posts again.
   In any case other than the ringing, your set up and signals look how they should look. And more than just good enough for me to follow up on.
   As you are not using an earth ground, you might consider connecting one up to your water pipes, or where ever you can find something to ground to. I get a better output when the ground line is also connected up to the transistor's emitter. And, perhaps  it might change the ringing signal at bit as well. Connecting up the yoke/grenade may also make some difference in the signals.
    We'll see what happens on my end, when I get to that point. As I do use an earth ground line, and have my grenade intact.    Sorry I can't be of more help, as I'm still waiting my parts to get here.
        NickZ
   EDIT.  I wonder if your previous simpler Kacher version which showed a sharper on off signal, might be a better way to go.
AlienGrey
Quote from: NickZ on June 09, 2018, 11:01:09 AM
        NickZ
There are a few things to take into consideration here and thought about seriously.
1/. is the device switching at the same frequency the Tesla coil is resonant frequency ?
2/. is the wave form clean and fast enough with clean edges and when it hits the device it's driving ?
3/. is the above resonant with your grenade setup ?
AG
AlienGrey
apecore
Quote from: NickZ on June 03, 2018, 02:36:20 PM
   Hows about showing a short video of your set up as you have it now. As well as any scope shots of the Kacher circuit working, etz...   When you have a chance.
                                                 NickZ
See the link, just a short impression of my current setup, showing the kacher interaction related to the voltage at grenade.
https://youtu.be/VP2jjTP22gw
