0 Members and 212 Guests are viewing this topic.
itsu
Quote from: NickZ on June 09, 2018, 11:01:09 AM
   Itsu:   Ok, well it looks like you have produced the same signals are what Stalker is showing. I believe he compresses the signal (on the scope) to obtain what looks like a sharper peak with not much ringing. I saw how he did that on one of his videos.
I'll look for that, again.
   I wonder if some type of snubber added onto the IRF4905 or the other fets, would help to reduce the ringing. Some type of snubber cap and resistor. Apecore had suggestion something earlier, but I don't remember all the details right now. Perhaps check his posts again.
   In any case other than the ringing, your set up and signals look how they should look. And more than just good enough for me to follow up on.
   As you are not using an earth ground, you might consider connecting one up to your water pipes, or where ever you can find something to ground to. I get a better output when the ground line is also connected up to the transistor's emitter. And, perhaps  it might change the ringing signal at bit as well. Connecting up the yoke/grenade may also make some difference in the signals.
    We'll see what happens on my end, when I get to that point. As I do use an earth ground line, and have my grenade intact.    Sorry I can't be of more help, as I'm still waiting my parts to get here.
        NickZ
   EDIT.  I wonder if your previous simpler Kacher version which showed a sharper on off signal, might be a better way to go.
Nick,
i think that the setup used in your ringingless kacher video (Adrian?) had a sparkgap at the end of the antenna.
I can imagine that that could cause the ringdown to abruptly stop when the spark fires as momentarily there then exists
a path to ground.
But to test we need a spark capable setup, meaning 1000V or more Kacher voltage and a solid ground.
Itsu
NickZ
Quote from: apecore on June 10, 2018, 04:55:48 AM
See the link, just a short impression of my current setup, showing the kacher interaction related to the voltage at grenade.
https://youtu.be/VP2jjTP22gw
   apecore:  Thanks for showing us your current set up.  I would be interested in seeing what effect the Kacher has on the grenade's output, but at the bulbs. Perhaps you can tell us what you see, as a result of the interaction.  I can see is the scope signals, which seam to look pretty good, but seeing what the effect has at the bulbs, is also needed.
    I notice that you are controlling the kacher pulse to hit the sine wave TWICE, both in the upward as well as in the downward pulse of the sine wave. Normally it's one or the other.  However, Stalker pulses the valley of the sine wave, and not the peaks or the sides. Would you think that that would make any difference? And what are you currently working on now?
   Thanks for sharing.
r2fpl
deleted..
Sorry, this is not the thread, please delete
NickZ
   Itsu:
   Anything new and exciting???
   I have not received anything yet.
itsu
Nick,
no, nothing to report as i stopped working on the circuits for now.
I have some idea's to try to get these ringingless bursts, but i don't know if and when i will be exploring them.
Thanks for the info.
Itsu
