0 Members and 99 Guests are viewing this topic.
zalmoxis
After a year of silence I'm back with new forces and new equipments (Spectrum analyzer and signal generator)
I wanted to let you know that I have managed to get the same results as Stalker did with his small TC4220 , IRF840 drived by the signal generator in pulse mode.
I have teste more than 8-9 grenates what i have built in the past 2 years and just one shows this specific effect. I will attach some pictures.
I want to add some notes, that wire length including ends is 37.5, wire is 2.5mm^2 , an wire diameter is 3,3-3,4mm
The grenate is winded in Ruslan mode/configuration.
The coil radiates maximum on her top head and at the exact frequency of 1,682Mhz
Inductance 324uH
Connecting the cold end to my so called ground (40m of heating pipes) the fluorescent lamp increases in intensity a lot!
I'm very happy to see this result after 2 years of hard work.
Please let me know if someone have got the same effect !
PS: my next step is to build an identical grenate, i will keep you posted
AlienGrey
Hi congratulations are in order, you must have standing waves. There have been any number of ways published on winding the grenade
I will have a look and see if I can find the original, and see if the effect can be duplicated, I have been a bit busy this last week
with a number of other problems so not much done on the building and testing,  s8uch is life.
Regards AG
AlienGrey
Can any one shed any light on this ?
AG
Bat1Robin2
That is the grenade coil it has a very specific wrapping the spot you refer to is where i believe the winding changes from cw to ccw or vise versa. The early post will show much more details.
bolt
Seems right too me. The kacher will run at any frequency it likes and it doesn't matter. Lets say 1Mhz  You then chop the katcher to provide sync burst to the collector coil.  The collector coil MUST have a known resonant frequency. In the Khz range lets say 38khz it doesn't matter so long as you know what it is.  The katcher sync is then timed to induce and create the collector 38Khz sine wave by precion burst of the tesla coil 1Mhz pulses.  There is no OU yet this is all sync and tuning. Need to add caps and fine tune the collector coil and yoke collector to max sine amplitude.. still no ou yet just tuning!
THEN turn on power fets to bang sine peaks. Using about 5uS slits and then you might get OU.
Problem katcher is a bad choice its a sloppy sleepy oscillator then keep asking it to sleep for 1500uS then wake up for like 10uS it has a slow start response time as the base current slews all over the place everytime you ask it to wake up so the burst is shitty.  You need a clock driven tesla burst but then you must tune the clock to the antenna and base induction coil aka normal tesla coil tuning.
