0 Members and 120 Guests are viewing this topic.
AlienGrey
There is also this the Ansis post. when you hit the right Lopt core gap spacing it burns out or blows up! got to be fast turning it off. sounds like a job for the back garden
Anyone got a cheap sauce of Lopt coils ?
magpwr
Quote from: AlienGrey on December 01, 2018, 10:09:39 AM
Hi i do have a ground earth available.
I notice you're using a train of pulses as far as I can fathom out a recovery time is required after each one, do you get any gain with your set up?
like a 1 microsecond pulse and a wait of approx 1.2 MHz wait till the next pulse but it needs to be stable re Master IVO  untried as yet
perhaps its a case of all the harmonics piled on top of each other at zero crossing overlapping yet another experiment.
Hi
AlienGrey,
Thanks for the quick reply.The gain I am currently getting is with frequency out verses IGBT driven frequency.The pulse version is merely good for deriving the frequency to use later on.
But the plasma isn't orange.I will be going to Akula design which I need to remove some winding on kacher such that it will be 1.8Mhz resonant then I will play with inserting AM ferrite rod. :)
This is harder way for me compared to playing with trimmer to control frequency which is currently provided by LTC6900 .
Regarding frequency overlapping because of divide by 3 .Yes there is pulse appearing on one upper node ,but not the next node,then appear again in another node.But once tuned correctly(Kapanazde output no longer produce  jumble harmonics) these odd interrupted pulse does not appear in the output waveform since low value cap eg:20nf 1kv is connected in parallel with bulb.[/color][/font][/size]
I am using jumper to select either A or B channel from IR2184 or both. This is after 1N5819 from IR2184.logic IR2111 works from around 10volts or more but IR2184 works with 3.3v ...5volts.[/color][/font][/size]
Because I am using microchip powered at 5volts for divide by 3 or 4017(5volts).
-------------------------------------------------------[/color][/font][/size]Regarding kapanadze coil tuning. I am using the sig gen ground and scope ground not connected together.The bottom of kapanadze coil is connected to pipeline the top of kapandze sig gen and scope probe is connected together.I did no bother staring with 4.8Mhz sine-wave but simply started at around  1.8Mhz then slowly tune down to 1.7xMhz until maximum amplitude is found.
For your case since you got 2 actual ground ,additional one you will need to create some distance apart from the electrical ground.This will looks like Tesla classic transmitter ,receiver  coil grounded which someone posted in form few years ago.But honestly not easy to understand for me if referring to the classic drawing.
I have attached captured photo from Akula coil tuning video.
I keep forgetting if sig gen trigger need to be connected to scope trigger input.It's late...
I can't find the video which was uploaded by Akula or stivep1 hence I have uploaded my saved video file into this location which will be valid for 30days.
Akula tuning video.
https://ufile.io/jq2vp
Please try it.
CLC is a programmed logic gates inside microchip and it does not depend on microchip clock.Please see my youtube video to understand that feature but it's optional to implement in current circuit.
I was the only guy in the internet is using this CLC feature apart from the tech team from microchip related to product demo.
I got to rest.late here.
spyder
yo can someone translate this guy....Anton Dremlyuga channel on youtube
..... the above circuit looks like his
https://youtu.be/uZskgb5lKqU
doktorsvet
AlienGrey
Data on the photo. The ground is 19Meters in from copper rod but if I add another 19Meters it's even better.
the waveform is flat with a sine wave but the square is full of harmonic peeks see photo.
