0 Members and 200 Guests are viewing this topic.
itsu
Quote from: Jeg on December 31, 2018, 06:30:00 AM
Thanks guys.
Itsu
I use a yoke core. 12T primary, 24 turns secondary.
Hoppy
No worries my friend, your opinion on what happens is enough! ;)
FYI this is the device that i am trying to apply the Q-topology. I find it very efficient by itself.
https://www.youtube.com/watch?v=manMnNOFdNI
Thanks Jeg,
a yoke would be a good toroid for this i think, perhaps i have to rewind my trifilar wire around one.
Using still the 5W/12V bulb at 60KHz.  12V from a PS for steady measurments.
Anyway, made some current measurments, see picture below.
A bigger picture can be found here (middle / bottom "Q currents.png"):
https://overunity.com/downloads/sa/view/down/670/
2 Watts total in, about 650mW across the 5W / 12V bulb, so dimly lit.
Itsu
AlienGrey
Itsu that's a nice 'CLEAN' waveform your producing there!  ;D   ;D
If I were you I would ask Karlo for a copy of the circuit he was using!
because that one your using is too clean you need loads of nano pulses.
Years ago Itsu I played with a diode it was brilliant all you needed was a pot a cap and a coil
and it would oscillate in the mid-end of the MHz band it was a tunnel diode ! just what you need here RAIL TO RAIL NOISE!
Question does your chip have a modulation input pin
Belfior
Quote from: itsu on January 01, 2019, 03:59:45 PM
Thanks Jeg,
Itsu
Trying to wrap my head around this. Does this circuit suggest, that we change DC to AC. Use the resonance in the coils to get some extra and then return the positive to the feedback. Then depending on our coil setup we have the negative half wave to use in our load? The question then becomes can we have the coil setup so, that we actually gain extra without losing the resonance?
If that is the case I would then change the L2 to a center tapped coil system. You could get L1 and L2 to resonate without losing resonance when the load is connected
AlienGrey
Quote from: vasik041 on January 01, 2019, 02:06:47 PM
Well, as far as I know Dr. Schwarz device use some interesting properties of Bismuth (but it could be disinformation). Where info about coatings coming from ? from the last video ?
Bismouth was used in a piezo crystal it's found in and around vulcanos (from what i remember from uni lectures
https://www.instructables.com/id/How-to-make-Bismuth-Crystals/
itsu
AG, Belfior,
frankly i have no idea what to expect here, signals sure look clean, and almost no spikes are seen like it should
according to V8Karlo.
No resonance involved also as far as i can see, just nice square wave signals between 10 and 100Khz.
We do transform from DC to AC (push pull) and via the feed back loop across C2 back as DC to the source.
I have 2W input and 650mW across B1, meaning we use 1.350W in the Controller/Push Pull section.
I do expect V8Karlo to comment now on how to improve on / correct this circuit so it matches his expectations.
Regards Itsu
