0 Members and 349 Guests are viewing this topic.
SolarLab
Excellent discussion - good paper - thanks;
IMHO
These fellows (physists) should take up smoking cigars - then; on a calm day with the sun
shining; watch the smoke (the field), composed of carbon atoms (the particles) as it rises
from the lit end and swirles as waves in the air (the aether). Then, take a puff and blow a
"smoke ring," or a direct full stream (the directed, fast moving, dense, wave field of particles).
Particles in a cloud field are "moving along" because of a potential difference (not voltage in
this case, but air pressure).
Heat, however, has charged the carbon particles and thus they adhere to things and build up
over time; like car windows or vents in a smoking lounge at an airport (yuk).
It encompasses all three: particles, waves and fields - so you don't need to discuss the
symantics, just define each clearly. Then just sit back and have a fine cigar with a good
Cognac! They will email your Nobel medal...  :)   [Hey, get your physics from an engineer]
Just my 'observed opinion' but it works for me! And, yes, I smoke cigars and sip cognac...
Naw, too simple - you won't get any funding for that explanation...  :(
color
The 2010 Nobel Prize in Physics is Graphene.
https://en.wikipedia.org/wiki/Graphene
Graphene has an electrical conductivity 100 times better than copper.
https://en.wikipedia.org/wiki/Bismuth
Bismuth is the most efficient diamagnetic substance metal on the planet.
By making two materials and magnesium capacitors, it seems that when Tesla works, excess energy is generated.
AlienGrey
Hi to all, I recently had an idea of linking the original Katcher device with the TL494  device as many of the TK and Ruslan devices
refer to a 1 - 3 phase lock, to do this I played around with the 494 circuits and found I could drive the device directly with my signal
generator directly with a mear 5v 50/50 EW wave unfortunately at 12 volt supply the frequency range is only 5khz to a maximum
of 30khz before it tails off. So if it's a 3 times wave for the Mustach wave how on earth do you sink a 30 khz wave with a 1.8mhz
katcher frequency? If the TL494 has a 30kz max then wouldn't the Katcher have to be in the kHz audible range in order to be a
longitudinal wave would you need to redesign the whole dam thing.
If anyone is interested pin 5 of the 494 will drive directly and 15 volts might be a better supply voltage.
Also at some frequencies, a Tesla coil with a decent top load produces scalar waves making a note of the frequencies
might well be important to tuning into with another device and looking into.
SolarLab
Quote from: AlienGrey on January 09, 2019, 04:04:35 AM
AlienGray,
Just another idea for you.
A couple of these (AWGens):
https://www.amazon.com/Akozon-Generator-Precision-Dual-Channel-Arbitrary/dp/B07G875LRD/ref=sr_1_1?m=A3H0LACWKJ270E&s=merchant-items&ie=UTF8&qid=1547056693&sr=1-1&keywords=dds
$30 US for (probably) a 15MHz dual channel [Arbitrary Waveform Generator] - burn 'em and you don't cry too much! Haven't tried these yet however - just ordered two - although have used a few PCB No Name types with good results.
NOTE: Sorry but I just bought the last 3 this fellow had (total 5). Price/performance was too good to let it go! If you need one PM me...
Driving something similar to this circuit:
https://vk.com/doc442363570_487639626
or this circuit:
https://vk.com/doc442363570_488467031
Theory here:
https://www.youtube.com/channel/UC0Ud8MyPx7hOKlWg66AcDnQ
You might already have the FETs.
Note: the TI454 osc is not that fast. Some other types here:
Synchronous Dual Mode Phase Modulated Full Bridge Controllers
https://www.analog.com/en/products/ltc3722.html#product-overview
https://www.analog.com/en/products/power-management/power-control/pwm-controllers.html
https://www.analog.com/en/parametricsearch/11481
Looks like the fastest OSC for these type of devices might be 1.0 MHz.
Good luck...
color
Hi.
I use Google Translator.
I only understand your message 90%.
What I understand is that the TL494 has a maximum frequency of 400khz.
Combining 74HC14 with TL494, we know that Mhz is obtained.
I do not have equipment to test, so I will upload a video to refer to.
https://www.youtube.com/watch?v=0SiXj_eK3oE
https://www.youtube.com/watch?v=odSqYvNyPLU
https://www.youtube.com/watch?v=U0M8VcWPfH8
Ruslan also completed his own circuit based on this schematic.
The trap is not in the circuit,
The traps are in a special combination of diodes and kacher, yoke transformer primary coils.
I am trying to find this.
https://www.youtube.com/watch?v=WV3posVDqJs
