0 Members and 408 Guests are viewing this topic.
Simple mind"Eugenik":  "Pseudo-"Herrenrasse", not only white, also to find in each other human-color "race " and specially when not color-related : the male/ female racism and adults/ youngster racism !
Real Eugenik : ARISTOKRATIE by demonstration,  IDEAL; Pythia( Physia)-Games,Delpi: body + mind competition
Same social targets by each his culture best way believe  ! Many ways " to heaven"
The Russian October/November Revolution by Lenin was paid by the Prussian royal war ministry, later this opportunity has had ( ~ Murphy's law) a bad feedback :
Sovjet= Rat and the "Weimarer Raeterepublik" what translated means                  " Weimarer Sovjetrepublik" , kommunist-socialist hard-core partisans  ;D   as parlamentarists and the base for the later"RECHT UND ORDNUNG"-Siechen Heil !- politics !
But the continent has a great patience ! Only impressed by the african plate , you know , a really Alp(- en) dream !
AlienGrey
Quote from: lancaIV on January 19, 2019, 09:56:57 AM
LancaIV I can't translate what your saying or meaning into English
is this what you're saying?
Simple mind "Eugenic":  "Pseudo-"Herrera's", not only white, also to find in each other human-color "race " and especially when not color-related: the male/ female racism and adults/ youngster racism!
Real Eugenic: ARISTOCRATIC by demonstration,  IDEAL; Pithier( Physical)- Games, Delphi: body + mind competition
Same social targets by each his culture best way believe! Many ways " to heaven". or demonic Alien recycling of soles
agenda.
Perhaps a better idea would be ignoring the programming and on death avoid the recycling  light tube and go straight up into
the galactic center and home, this (NDE) suddenly the world is just full of negative energy you no longer care about.
Void
Quote from: Jeg on January 19, 2019, 03:17:32 AM
Hi Void
What about when the load itself is just 1 ohm? I mean i measure across it a certain voltage. Isn't that value the same for current and for Vrms? At 1 ohm i see an Rms voltage of 14V. So voltage is 14V and current 14A. V*I=196W.
Yes if you are interested in this measuring method, i'll make video for discussion.
i found equation here https://sciencing.com/calculate-time-heat-water-8028611.html
and online calculator here https://bloglocation.com/art/water-heating-calculator-for-time-energy-power
Hi Jeg. Thanks for those links. Those are useful. If you make a video using that approach
I will be interested to see it.
Yes, if you are measuring both the voltage and current across a resistor, the voltage and current should be
in phase, if the resistor doesn't have any significant inductance. At higher frequencies even a small amount of
inductance in a resistor can throw measurements off considerably. As far as trusting the RMS values, it can depend
on the waveform shapes and exactly how your scope is calculating the RMS value. Also, if the current is not flowing
through the resistor for an entire period, but the voltage waveform extends further than the current on time, then the
voltage RMS reading of your scope could quite possibly be giving you incorrect results in a power calculation.
All the best...
Jeg
Quote from: Void on January 19, 2019, 12:11:47 PM
All the best...
Void
Thanks for the advices. Everything you said are very correct. Current flows during the whole period. What concerns me more, is Frequency vs any possible R/inductance as i work in the range between 180-300Khz. I hope the heating measurement will reveal any possible error. I don't expect high accurancy though. I insulated my water glass container, but still the top of the glass remains open.
Void
Hi Jeg. That should still be an interesting and informative test however.
I will be interested to hear how you make out with that type of testing approach.
All the best...
