0 Members and 294 Guests are viewing this topic.
color
AlienGrey:
I like the idea of ​​zero point energy but I still do not understand it. The Katcher appears to be in the MHz range, but the push-pull
seems to run in the kHz range about 15kHz and the Katcher is about 1.7mhz so how do you get a divide by 3? waveform lock totaly confusing from an educational point of view.
PS should not the Earth go to the earth so it sucks the depleted charge carriers from the earth?
I do not have good English skills.
The zero point energy,
In quantum mechanics it is the energy that a particle has in a ground state. Under the uncertainty principle, even at the bottom, the energy can not be zero and it has the minimum energy, which causes superconducting phenomena and superfluid phenomena even in absolute zero.
In classical mechanics, the position of equilibrium is the point where the potential energy is minimum (that is, the potential energy is 0 when the kinetic energy is 0), but since the position and momentum can not be determined at the same time by the uncertainty principle in quantum mechanics, Even when the energy is minimum, it is impossible to realize the state where the particles are stopped (i.e., the state in which the kinetic energy becomes zero when the potential energy is zero). In this case, the energy represented by the value of 1 (h is the Planck's constant) is the zero point energy when the energy is the lowest state, that is, the energy possessed by the floor state, for example,
More specifically, for example, when an electron orbits around a nucleus, the orbital motion must stop at its lowest energy state. However, the orbital motion of the electron actually continues without stopping, and the energy that keeps the orbital motion at this time is the zero point energy. The reason why superconducting phenomenon or superfluid phenomenon (current flow or liquid helium flow) occurs near the temperature (or at the resistance 0) without stopping the object which should be stopped at the absolute temperature 0 K, Because.
Each year, around the world, 1.4 billion lightning appear,
Of these, 90% are negatively charged.
The maximum current of a lightning bolt is about 30,000 amps, and the current flowing time is about 30 microseconds.
Compared to lightning, the free generator generating 5 ~ 6A is 1/5000.
According to the first law of conservation of energy, energy on earth is separated from balance and imbalance, but the total charge is preserved.
I understand the strange imagination that some people will run out of earth positive charge.
It is not my problem to worry about the sea water getting dry.
Tesla pulled the grounding force out of the capacitor,
What will you pull out?
Many people eat food if they are hungry.
If you do not eat food and think about what the food is made of, the hunger does not end.
https://www.youtube.com/watch?v=atALbOXRnE4
If you're just thinking about showing a flashing video
You end up thinking forever.
It is not too late to think of you after completing your free generator.
Just as we make hydroelectric power plants using water drops,
You can also make free generators using the principle of lightning.
Studying how water is made,
To study how to make lightning,
Curiosity is a good motivator,
Water and lightning are micro-world events we do not know.
Like me, you understand only principles, not all.
Just like you do not understand quantum leap.
Thunderstorm progression stage
Stepped Leader - A small lump of negative charge that drops down from the cloud to the ground along a small current resistance path.
There is a trace of ionized gas in the path of this lead. In the meantime, the organizer has a length of tens of cm and microseconds
Move step by step. After one step, the organizer rests for about 50 microseconds and moves to the next step.
At some point, the body 's charge is broken up into several lengths.
When a lead comes close to the ground, the electrons on the earth are pushed out and a region of positive charge forms.
Here a corona discharge takes place and reaches the approaching lead. When the downward connector and the rising corona discharge are connected,
A continuous length is formed between the clouds and the ground, and a strong rebound lightning begins.
Return stroke - The return lightning takes the nearby electrons along the traces of the ions created by the stepper
Move quickly up. After this rebound lightning disappeared into the clouds, the lightning streak could end up in the amount of the remaining charge
You can do it again.
A dart leader - if there is enough charge in the cloud, the arrowhead along the path may first come down to the ground.
And this arrowhead causes a second lightning bolt.
A lightning bolt usually consists of three or four lightning bolts, and the distance between lightning bolts is about 0.04-0.08 second.
There are two influential theories about theoretically explaining how a cloud is biased.
1. Convection Theory: Free ions in the atmosphere are caught by the particles in the clouds and gathered in some part of the cloud, carried by the air currents.
2. Gravity Theory: Negatively charged particles are separated from lighterly charged particles due to gravity.
color
NickZ:
I never found connecting a ground to the transistor base circuit to work for me. I always connect the earth ground (37.5M) to the transistor emitter, instead.
   It depends on the Kacher oscillator circuit that you use, if you connect the earth ground to the emitter, or to the base of the transistor.   I use the emitter to earth ground connection, instead. As compared to what is shown in the last posted diagram.
You use 2SC5200 transistors.
You must understand that the generator connects ground and minus to the same line.
So where should we connect the diodes?
magpwr
Quote from: color on January 26, 2019, 06:00:04 PM
NickZ:
hi color,
I forgotten to mentioned that the tesla circuit is operated independently.There is no synchronization with PWM circuit.Using stalker circuit...
Nothing else to add.
color
magpwr:
hi color,
I forgotten to mention that the tesla circuit is operated independently.There is no synchronization with PWM circuit.Using stalker circuit ...
Please let me know which schematic you use.
You do not have a free generator if the Tesla circuit works independently.
You must cooperate with Push-Pull.
In order to cooperate, each other must be connected.
And,
Ruslan has asked Mr. stalker for a free generator video that works.
Mr. stalker did not respond.
There is also a trick in stalker's schematics.
magpwr
Quote from: color on January 26, 2019, 11:45:33 PM
magpwr:
hi color,
And,
hi color,
Now that make some sense related to synchronization.I do notice stalker circuit base on your attachment base on the waveform was shown as around 25% duty cycle.Lower the duty cycle will also create lower voltage output at kapanadze.
May i ask do you understand Russian language.
