0 Members and 357 Guests are viewing this topic.
Jeg
Quote from: NickZ on January 31, 2019, 05:16:09 PM
  ....But, I see no magic due to any grounding, just an improved output.
...Input goes up at resonance.   Possibly we need to consider that there is something more to it than normal circuit resonance.
That is the voice of experience!  ;)
Yes we are on same page as i am also trying to find what Ruslan never said or showed. That is the place we have to search for. There is absolutely nothing for me behind all those published circuits. I believe that Ruslan starts by having OU at his yoke core. Then he amplifies the result at the output of grenade by using the same teqhnique. He also stated that, but i can't find his statement inside all those pages.
Sooner or later...  :)
Hoppy
Quote from: Jeg on February 01, 2019, 04:29:45 AM
Hi Jeg,
If there is any truth in the OU claims then the most likely explanation IMO is that the yoke core acts a fuel. Kapanadze clearly shows that there is nothing critical about the length or gauge of the ground wire. I think Nick is beginning to realise that building a device based on the published circuits is futile unless the principle of operation is fully understood. Some of us have spent countless hours frigging about chasing the rainbows end, with various builds, whilst being clueless about the modus-operandi.
color
Jeg:
Russian cafe Some members had been playing with a device similar to the yoke coil that Jeg had made.
The difference between the arc caused by the coil winding and the charge equalizing arc pulled from the ground by the kacher is clear.
The cafe there was not in an atmosphere where I could speak freely, so I was forced to silence.
They banned my writing.
It was very unfortunate.
Hoppy:
Resonance boosts the kacher + current produced by the diode bridge to the primary coil of the yoke transformer.
If the amplified current passes through the grenade again, an inductor-induced amplification occurs again.
This is the iterative principle that it is transmitted back to the yoke transformer primary coil through the diode bridge.
When the generator starts to operate normally,
Meanwell is only responsible for the current in the push-pull and kacher circuits.
If you understand this principle first, it is easy to work.
Jeg
Quote from: Hoppy on February 01, 2019, 05:18:26 AM
Unfortunately this is how things work. Realization comes only after active involment on the subject. The same fruitless effort applies to the most published circuits like Acula's e.t.c
But... what we can do other than keep searching! :)
Jeg
Quote from: color on February 01, 2019, 05:41:16 AM
Jeg:
Yes it is clear that people's attitude changes depending on the cafe you are writing to. But.. results are the same no matter the caffe..
I read you closely and i like your bench work. Keep it up! ;)
