0 Members and 81 Guests are viewing this topic.
NickZ
   Color:   There are a couple of things that I don't understand. First you say that you don't have a replication of any device, but that you have taken one apart, and so it's not working now. Then you show a video showing your device working to light a small bulb.   Ok, I need to mention that lighting a small 20w bulb, with higher than 20w of input is not very useful, nor is it self running, nor OU.  Better to connect the car bulb directly to the battery.
   A better test would be showing the interaction of the Kacher to the induction circuit by lighting at least 200w to 300w worth of bulbs. WHY? Because that would show and prove that there may not really be any actual useful interaction going on, just the small additional power added to the induction circuit by the Kacher from it's input source, to light a small 12v or 24v bulb.
Therefore, big bulb(s) will NOT get any brighter, when using the higher wattage bulbs, instead. Imagine connecting 1000 to 2000 watts of load.    Point being that you are not showing anything that is actually working, but you made an effort to do so. That is more than many of the guys on this thread have done. Yet, you found the same results as the rest of us. No real and useful interaction, no OU, nor able to self run.  Right???
   Below is an older video by Geofusion. Here he is showing the lighting of a 100w bulb, and the interaction of the Kacher to the induction circuit. He was using the simple Kacher in this video, similar to yours, so that you can see that even without a controllable Kacher circuit, there is some interaction. Keep in mind that he has no feed back loop at that point, and his 24v PS as his input source is a 360w unit. The light bulb is only 100w.
  His newer videos with his new update controllable drivers produced even better result. And he was connecting up a feed back path, also. But, this video below is an older replication.
   https://youtu.be/7ELg1TclytM
   Below, is one of Geo's modified diagrams from 2016, second image below.
    Here I am partially lighting 3 200w bulbs, using a simple Kacher, such as was shown by Ruslan in his "TopRuslan 7" device.It was difficult to actually obtain brighter bulbs when connecting the Kacher up, also. But, those bigger bulbs did light up a little brighter with the Kacher on. That was as far a I got, at that time.
     Color: You mentioned that my 37.5 earth ground line is not working. Why do you think that? If I disconnect the ground line, the bulbs dim by a lot.
   I don't expect to harvest anything from the Earth, but from the surrounding ambient, instead. The ground line is just a ground path, there is nothing coming from the ground. But, there is some power going through to the ground. As Geo shows.   I don't use diodes on the ground line, and Geo does not as well, as far as I can remember. We both tried them, and ended up taking the diodes off of the ground line.
magpwr
Quote from: color on February 02, 2019, 05:55:15 AM
Hoppy:
https://www.youtube.com/watch?v=yOGD1WkJJok
r2fpl:
https://www.youtube.com/watch?v=-TDJwOfAm20
It was rumored to be a vasmus circuit.
Now, any member can know where the error is.
hi color,
I have attached piece of Vasmus circuit and stimulated version from part of his circuit.
I am unable to connect the dots maybe you or someone else can.
Nothing to add.
AlienGrey
Magpower
Hi, what do you want to know, he has a surgery thread on the net I found some time ago but hard disk got corrupted
and I lost it, but i think i stuck a hyperlink on the thread at the time, are you on skype only its illegal to publish
or copy others work on this type of tread in EU (Babylonian logic).
The transformer on the front left is a microcrystalline alloy is his secret but rest is TX-RX.
AlienGrey
Quote from: color on April 04, 2018, 12:48:27 PM
AG:
I found this cafe around 2011.
I just watched a lot of your opinions.
You may be unfamiliar with me,
I am familiar with café members.
So I recognize many opinions in the cafe.
I will say one more time
Geo schematics do not generate additional energy.
My 40mm PVC pipe turned over 10 degrees.
So I replaced it with 40mm aluminum pipe.
Thanks to Geo schematics.
Hi, Color will it work with copper pipe and how did you cut the section length ?
