0 Members and 410 Guests are viewing this topic.
AlienGrey
steadyfield
to NickZ & AG:
Thanks for your replies. For the old failed replication, I forget the exact frequency that the kacher/tesla and the push-pull are running at.  The push-pull runs at 11-17kHz. The tesla coil has many taps as can be seen from the pic. The highest frequency is around 1.2MHz with the antenna over the grenade connected. That might be too low to excite the grenade coil.
For the new replication, I decide to rewind both the tesla and the grenade windings since I have enough materials. Could you recommend the length [coil 'height', not the wire length] of the tesla coil to start with? I have 0.8mm enameled copper wire.
For the inductor coil, I happened to find a coil from the SR193 replication (which also failed), and the wire length is about 10.4m. I decided to unwind it and use it as the inductor coil on the grenade MAIN winding. That would fit into 2 layers. I want to make the inductor winding "thinner", to make it easier for interaction.
For the ground, I live in a high-rise apartment, and am using the metal water pipe as the ground. I tried to use the EARTH from the AC socket, but it ends up triggering the fault protection breakers. In this case, how should I calculate the length of ground wire? Is that "L[ground]=L[water_pipe]+L[wire_from_the_water_pipe_to_the_device]" or simply "L[wire_from_the_water_pipe_to_the_device]"? I might simply use a short "L[wire_from_the_water_pipe_to_the_device]" to begin with.
will post further progress there.
PS: I do not understand the following picture "only unipolar pulses work here!". How is the pulses waveform measured? If one simply puts the scope probe around the tesla/kacher or antenna, one will see the waveform showed on the scope to be AC signal with no DC component because it's capacitive coupling. Also, what is the impedance transformer? Is it necessary?
AlienGrey
Don't you have to mix the Kacher sine wave with the inductor push-pull sine wave? the maximum freq of the TL494 is 400khz but your using a CD4046 just right to tune mustache 3 to 1 wave I would have thought re Enjoykin post in dally thread. Have you tried that ?
Hoppy
Good to see this thread back on track. There's a coffee shop next door for anyone wanting a break from building.  ;D
One observation from the Kapanadze green box videos is that the earth wire is taken through the centre tube of the grenade and connects to one leg of the load. The other leg of the load is connected to one end of the grenade winding. I do not see this in any of Ruslan's setups.
Jeg
Quote from: Hoppy on February 03, 2019, 11:16:47 AM
Ruslan connects his load before grenade which essentially is the same, and this indicates an in series resonance rlc. I work on a similar system and I see it. The lower the load resistance (which points to kw) the higher the current..
Ps. The cap in kapanadje is in the green box
