0 Members and 131 Guests are viewing this topic.
Tynoo
Hi guys,I found this...
"RuslanT.:
Posted March 11, 2016 - 04:34
Good time of day. Maybe here we will find a common language. I must say that I'm not sitting on the forums much. No time ! However, now for the 5th time I collect Akulin for installation to increase power. There are ideas .... And in fact, people are looking for a bit of everything. All these systems operate on the basis of standing and traveling waves. We must first catch the movement of particles in the coil. Those. like Kapanadze and does with a tester or ammeter. Only at RF frequencies no ammeter will help and you will need to catch an oscilloscope. The first rule: wind the coil 40 meters. 2. Find out its resonant frequency (1/4 wave) Inductor 1/4 = 10 meters of the same wire (for example, 2.5mm) Connect the generator to 10 meters coil, drive the rectangles at a frequency of 1 MHz and crawl up until 40 meters no sine wave appears. Maximum amplitude. The generator is desirable to take a normal laboratory! With adjustable output from 0 to 20 volts. We achieve the maximum amplitude and move the tenths of a kilohertz until the sine begins to dance. This is your wave resonance !!! Fix the frequency and voltage. This is what all generators have to do. Further ... Tesla we shake under this frequency that the effect has turned out. Then we do everything as I did or Shark. In this case, everyone wants to repeat this device. Forward! We fix everything beautifully and firmly, not forgetting that the resonance and the effect can escape in the case of snot mounts. We need to get the very effect and work, not a ready-made device. As soon as you begin to understand what to do next, you will be able to move yourself. So .... Tesla, as we know, also wets a sine wave. Suppose your frequency turned 1,821 MHz. Crappy frequency, but alas. We'll have to set Tesla on her. The shark applied a firtik between Tesla and a toroid (Antenna) over an inductor. This is exactly the exact adjustment. It is needed before launch. Then the system holds and no matter where that has slipped in not great limits. But! Again ... What where? On the Inductor we give a signal of rectangles with a frequency of 1/50. We count: 1820: 50 = 36.4 kHz pumping by a rectangle through a junction (Pot) with 23-29 turns of a wire 2.5 squares. I repeat, you need to make a voltage for this harmonic not 10-20 volts, but higher by an order of magnitude. Up to about 50-60 volts and get the same dancing effect on the output. Further ! Do not forget that Tesla does not need strong power. Do not let the sparks and watering so that punched. This is not necessary !!! Better to make a controlled Tesla. We continue: A voltage of 195-200 volts will appear at the output. This voltage will not be higher. Why Let's come back to this later. It is necessary to wind the transformer - reactor (coil) in order to obtain the required voltage. This requires experimentation. Remember that we are pushing current in a reactor using a shear wave. Created by Tesla. In the coil, another wave forms under the influence of pumping rectangles. Particles of which constantly rotate left and right. Giving them a pulsating Tesla motion, we accelerate them in the conductor itself. This is a hemorrhoid understanding, but a fact. Tesla should be triggered in one half period or from one arm of the transistor. It is advisable to control Tesla to carry out a pack - a pulse generator. When everything is clearly set up, you will see how the effect appears when the width of the pack changes. Tesla's consumption is scanty, and pumping does not strain at all. Output current up to 7 amps and voltage 200-209 volts. Light bulbs and power supplies pulse work well. Now for removal: 1. The coil is connected via a diode bridge. No parallel capacitors !!! 2. You need from Tesla only one half wave. Otherwise, Tesla will take back what she gave back !!! Therefore, the diode from the ground to put on the very coil of removal (40m). Shark did it at the reception. He removed one part of the sinuses at the very reception. Because Tesla. Nobody knows this, and to-the-day to this day, nichrome does not work. It is clear! You need to swing the swing in the coil of energy removal. It is there that we push current. By the way, the surplus from the tesla and the frequency setting The shark used a simple light bulb. Since the Inductor is galvanically decoupled from the whole circuit, the light bulb served as a resistive load for absorbing excess tesla and pickups. You can not put, but do not swing Tesla strongly. Do not ! Remember that the current is subject to voltage. I see this from experiments that I spent 2 more years ago. Next: The diode on the pickup coil removes one half period and so we swing the oscillations without slowing them down with the negative Tesla period. This, too, many do not know and continue to sculpt. That is why Roman (Shark) speaks about what eats ground ... That's right! Because he kills the impulse of the period on the reception, which is grounded. This is evident in all its installations! I wondered for a long time why he had applied this solution and realized that it was easier to choose explosive diodes. Since the intervention of such frequencies in Tesla will lead to its not working properly. In other words, cut half time will not work. Kap this issue was resolved by the arrester and rectifiers at low frequencies. There sun "
https://realstrannik.com/forum/freeenergylt-antanas/708-povtorenie-ustanovki-free-energi-kolobukhova?start=954
GeoFusion
Hi all,
Thnx Nickz for sharing my link on the forum.
I saw your recording, nice job on the experiment.
On almost burned filter there, so around 30V / 40V DC right?
You'll need add or build better protection and that it could handle the input.
Should try to build the Akula Kacher and try that one out.
Try to build the Sergej Panov kacher circuit as well the one he got from Ruslan, the one I have shown in the vid.
should be also within the forum for sure.
It should handle the nasty voltages as well.
I had to deal as you saw 100VDC to 150VDC ~ input. from the 28T~30T secondary.
the real work will begin when output gets rectified and caps placed.
There are experiments that still have to be done in the fashion of Vasmus style.
Ruslan did somehow manage it I see and that form has potential to be easier in my opinion.
Steadyfield did touch the subject a bit and posted some of the pics about it.
Will elaborate a bit on that one below...
Oh and saw that video you posted on that star gate,  very interesting, but will not elaborate much now.
Justawatt,
I saw the video and the schematic you posted,
and yes I have done this long time ago and works.
It's the same as holding a Iron/ Alu plate suspended in air close to the antenna and having the plate connected to a wire
that will be connected to a bulb and right after to the ground. it glows. it's just that the Grenade is
of more mass, it could produce bit more, especially when it's in good resonance with the antenna/.
Nothing to special here if familiar how radiant energy works.
Hi Jeg
Glad to be around for the moment
To All
About the Mosfet at the output of the receiver coil, this is where I want to point out something on.
Did you all realize how Vasmus has it connected?
Lets simplify something here.....
If you, take a 12V battery, place a diode on + terminal and connect a inductor (coil) the other end  is free contact
The - terminal to connect on the capacitor ( Non polar) which you want to charge.
Cap can be one of those 30uF lets say  400V rated for example.
You will now begin to tap the free end of the inductor the + side ( toroid)  on  the capacitor which has terminal open
Only taps, and fast taps on the Cap terminal with the + . While doing this, put your voltmeter on DC
You will gradually see that you could pump the cap with a raising voltage  in a way and when you connect a bulb
over the terminals of the cap, you see (depending on how much you charged) a good bright up for a second.
Now imagine that being repeated under Very high speeds of pulses and constant. You will have a constant charge
and this is Reactive, It's actually switching this is called. You will able to light up so much if you have it correct.
This is my thoughts and research on Vasmus  style systems and what Ruslan Did some time ago.
The cap is then your reservoir of mass energy. In Vasmus videos You could listen to vibration on the Vasmus table,
there is a relay busy there receiving every pulse delivered to it from the cap(s) being charged.
Mass generation of current will be available.
think about this...
Cheers.
forest
GeoFusion
Picture of this capacitor experiment would help.
GeoFusion
Quote from: forest on February 13, 2019, 04:14:58 AM
GeoFusion
Hi Forest,
Which capacitor experiment would? Which picture?
Let me know.
Justawatt,
Ok.
I might make a short video on
your posted diagram.
AlienGrey
Quote from: GeoFusion on February 13, 2019, 12:03:04 PM
Hi Forest,
Let me know.
Quote from: AlienGrey on December 01, 2018, 07:57:07 AM
I found this on the Don Smith thread,
If you can find the tread there is a very informative video
If anyone builds it let me know if its overunity or not
Hoppy notice the wires dawdling off to the grid on the left Ha Ha!!  :'( ;D ;D
Justawatt,
Ok.
|Geo on the Don Smith tread you showed a vid of a pile or series 330nan caps fed from an EHT supply
could you both be commenting on the same thing here.
