0 Members and 246 Guests are viewing this topic.
T-1000
Quote from: AlienGrey on February 15, 2019, 12:28:48 PM
Hi Arunus, I don't suppose you have any clearer details on that circuit or the formula for finding the capacitor values or the wave form we are looking for ?
From what I've seen already so far the LC tank circuit might end up to be 2x frequency of resonant frequency from yoke. But again, will see only in trial and error way.The complete isolation of grenade from ground over capacitors should let keep area inside of grenade always charged. Same approach as in very old original Tesla coil - just in reverse.
And most people just missed moments  in Sergey Alexeev/akula videos where "Radio Moscow" sound is coming from grenade and not from yoke...
Cheers!
steadyfield
Quote from: T-1000 on February 15, 2019, 01:42:12 PM
Cheers!
Hi, T-1000. I have some questions regarding the schematic "missing caps.jpg".
1. from the schematic "missing caps.jpg", there is no push-pull, no tv yoke core, and there is only a kacher as the driving source. You said that "the LC tank circuit might end up to be 2x frequency of resonant frequency from yoke", what is "the LC tank circuit" and what is the "yoke"? For my understanding, "the LC tank circuit" refers to the grenade with the three capacitors you added. And the "yoke" refers to the CORE of the "asymmetric step down transformer". Are these correct?
2. If 1 is correct, what is the "resonant frequency from yoke", is the "MATERIAL" resonant frequency (for example, NMR/FERRO-RESONANCE, etc)?
3. Is it necessary for the grenade to be wound as "zero-inductance" (Layer1-CW, Layer2-CCW, Layer3-CCW, Layer4-CW, Layer5-CCW, Layer6-CW, for example), for this device to have OU? As can be seen, the grenade used in this device ("kacher/tesla+grenade") is different from the one used in Ruslan's "push-pull+kacher/tesla+grenade" device. For the latter one, the inductance of the grenade coil is not zero.
Can the grenade coil be replaced to a pair of bifilar coil connected in opposing mode (the net inductance is also zero, see #20513) ?
4. about the "asymmetric step down transformer", could you explain to us how does it work (important!!!) ? The size, material of the core, and the winding parameters of it? Is the attached image correct?
many thanks!
T-1000
Quote from: steadyfield on February 15, 2019, 09:57:33 PM
There are two typical implementations.The one represented in the picture does not have series LC for strong magnetic field inside of grenade coil.
Quote from: steadyfield on February 15, 2019, 09:57:33 PM2. If 1 is correct, what is the "resonant frequency from yoke", is the "MATERIAL" resonant frequency (for example, NMR/FERRO-RESONANCE, etc)?
No, it is series LC resonant frequency tuned to the odd harmonics of natural frequency of Tesla coil + grenade (capacitive receiver)
Quote from: steadyfield on February 15, 2019, 09:57:33 PM3. Is it necessary for the grenade to be wound as "zero-inductance" (Layer1-CW, Layer2-CCW, Layer3-CCW, Layer4-CW, Layer5-CCW, Layer6-CW, for example), for this device to have OU? As can be seen, the grenade used in this device ("kacher/tesla+grenade") is different from the one used in Ruslan's "push-pull+kacher/tesla+grenade" device. For the latter one, the inductance of the grenade coil is not zero.
That comes down to what function is.And as you may know already the metalic plate next to Tesla coil acts as powerful capacitor plate. Which is able to do useful work when the next connection comes from the ground over load.So the grenade function is towards LC network working as capacitor.
Quote from: steadyfield on February 15, 2019, 09:57:33 PM4. about the "asymmetric step down transformer", could you explain to us how does it work (important!!!) ? The size, material of the core, and the winding parameters of it? Is the attached image correct?
many thanks!
This one have interesting aspect of what we call "cold electricity". The transformation of energy of particles involved is not same as with electrons due atomic properties of particles. To be fair, it is grey area what actualy happens when it meets "cold" wire from the ground and how the magnetic fields are aligned for transformation we need. The suggested approach is to treat it with 90 degrees arrangement.In general function - it is ultrasound frequency range step down transformer.
GeoFusion
Hi all,
Where should I start..  :)
Quote from: NickZ on February 15, 2019, 09:23:24 AM
    Geo:   What voltage is going into the Kacher circuit? What is the duty cycle reading at the transistor?
   I'm wondering how you don't burn up the Kacher transistor, as mine gets hot after a while on just 24v.
   Also what is the input wattage to both circuits?
   I don't know if either the bulbs or the circuits can handle those arcs that you're showing on the video.   Remember that you'll have to put that output back into the input. Will it handle it? Does it really need 150v input to the Kacher?
Akula showed 3mm sparks on the ferrite rod, on his second self runner, or about 3000v.
   You had shown nice loud and intense white arcs before. Same as Stalker has shown.
Nickz,
At current stage voltage is between 100 - 110 VDC input to kacher. It can be fed 150VDC as well on current setup.
Variable voltage for Tesla coil is necessary to get desired results from your grenade.
Duty cycle must be on vary.. not sure on that one but when you change it ofcourse it changes your input,
Because I only measure the input voltage on DC going to primary of the tesla coil is how i see how things should be
at the moment, and how it ionizes the air and everything around it. Even my hair stands up at some point.
As a small summery,  certain voltage lvls are needed for certain points of ionization.
Amp meter shows almost 4 amps at the moment. on driving, ofcourse it changes while playing with the duty cycle.
the voltage can even light a 7W 120V bulb without blowing it/burn out , only when the 3d part is implemented after the output,
it will be more of a Reactive output, where it can be very different.
do not apply any of the knowledge of commercial science of electricity to
this point when working with these devices. it's an advice.
It's almost always Uncharted waters while working with these tech, mind has to be open for new things constantly.
At some point the energy has memory and have to play with Mass of Metal to get desired results.
Akula did show his amount of sparks in old vids, but he grounded his system while it was in operation.
it also demps the streamers but increases the operation for what needs to happen inside grenade.
Justawatt,
input power is not affected by putting more load, but is limited till certain amount of wattage
Steadyfield,
I suggest you follow the diagram which T-1000 posted on following the way of coiling the Asymatric transformer.
number of turns .. as reference we could use what ruslan did.
About grenade being  near zero inductance, yes, but after don't wrry much want happens when connecting extra circuitry or wires.
Grenades purpose is to harvest/resonate and also create amps with the amount of voltage being generated.
cheers~
justawatt
Geo
Why I am forcing u to check the circuit is because
Some one told he has looped this circuit.but not
Willing to say the rest what he did.
He told me to follow this circuit that's it
What he he has is shorted coil.
For 7 months I have no reply from him
