0 Members and 177 Guests are viewing this topic.
magpwr
Quote from: justawatt on February 16, 2019, 12:49:54 PM
Geo
Why I am forcing u to check the circuit is because
Some one told he has looped this circuit.but not
Willing to say the rest what he did.
He told me to follow this circuit that's it
What he he has is shorted coil.
For 7 months I have no reply from him
hi justawatt,
I do notice the duty cycle applied is very narrow maybe 18% and the tesla coil is energized on both channel of pwm.
I real reason i replied is because i think you know Russian which this small duty cycle is able to create high current.This matches another unknown device which belong to a Russian which i am watching closely which i may need your help to translate and help us understand.
He is using narrow pulse to light a bulb which i find is extremely interesting.https://www.youtube.com/watch?v=KKgkwXrKNBM
Void
Quote from: magpwr on February 16, 2019, 09:49:26 PM
Hi magpwr. Do you know the exact input power and the power rating of the bulb?
If not, then it is just another light bulb lighting up video where we have no
real idea of the actual performance. If the input voltage is high enough, even a narrow
pulse width can transmit a considerable amount of power.
I think justawatt is in India.
color
If you want to discuss kapanadze generators, start over here again.
[ 1482 ] 1483 1484 1485 1486 1487 ... 1516
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474393/#msg474393
cheappower2012:
February 17, 2016, 03:55:25 AM ≫
People don't get just how devious Tariel is,he says things untrue because he knows that people will focus on them,there red herrings.I can't get a certain this or that,people grab and run with it.Tariel and SM inventor of the tpu think the same,fake out people looking to replicate there devices.
The kapanadze device has nothing to do with Tesla,he says it does so people will focus on Tesla.Hoppy's approach is  correct, if a device is a possible fake ,can I show it could be,you don't want to spend time investigating a fraud believing its real thats madness.However  you have to be very careful that you don't declare a device as fake, but it really maybe real.The picture very much sums up how complicated figuring out Tariels device is,without a core concept.From a logical stand point the blue coil is simply that a long coil wound in different directions,an air core,a current must flow between the ground and the end of the coil,to a load(heater).At least 9 amps must flow to light the heater,the coil has very little inductance,winding it in different directions  causes the effective inductance to be less than a simply wound coil.The other end of the coil connects to the 3 phase transformer with a resistance of 78 ohms,from a logical standpoint it must therefor be a fake,since its impossible that it could work.To make Hoppys theory correct you would have a small wire shorting the transformer connection where the blue wire connects.A wire goes to this connection hidden,in back of the transformer this wire then connects to the bundle of wires,this then goes to the back connecting to the long out side cable,and the mysteries
solved.You can see that this is a very hard problem,this is why the giant brains,more or less gave up.Keep in mine I believe its real and uses principles very different from how I was taught in college very hard to
figured out, both the tpu ,not all are real,and kapanadze's devices operate in similar ways.
Zeitmaschine:
February 17, 2016, 01:30:35 PM ≫
This is also true for the drawing below (Patent US6104107).
https://patents.google.com/patent/US6104107
The secondary L2 of the high voltage transformer (Alternating Density Generator) does not form a closed electric circuit, hence it can't generate a magnetic field, hence there should be no counter EMF in that transformer. Nevertheless an oscilloscope connected to coil L3 measures clearly some sinusoidal voltage, meaning, the coil L4 must generate a magnetic field somehow. Impossible?
Not according to my experiments. Although a capacitor in parallel to L4 is necessary in order to work at the low frequency of 50 Hz (not 1 KHz to some hundred KHz as mentioned in the patent). The capacitor and L4 must form a resonant LC circuit at the frequency of the AC source (this corresponds to the 3-phase parallel LC circuit in Stepanov's carpentry setup).
Here connection Bx6 would be the point where Kapanadze put the clamp meter between in order to measure the (impossible) ground current. So far my meter shows nothing, but then, where is the energy coming from that generates the magnetic field through L4 (also open)? Obviously not from the AC source because the open L2 can't generate any counter EMF.
What's missing here? Is it perhaps the simple frequency doubler circuit like seen in the Stepanov's cardboard box setup in order to get a special resonance?
Just something to think about ...
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474485/#msg474485
Zeitmaschine:
February 17, 2016, 05:50:04 PM »
What is electric (ground) current? In order to measure an electric (ground) current by means of a clamp meter the electrons in the wire must generate a magnetic field around that wire. Otherwise the meter will show nothing.
So how to accomplish this without a closed electric circuit? This is the main question here!
In Stepanov case (image to the right) the only way to fake that ground current (here the battery is the conductive body) would be to tamper with the inverter - namely creating a short between the 12-V-in and the 220-V-out side within the inverter in order to have a closed circuit.
But then the question comes up: Why should Stepanov showing a fake ground current without good cause? Why unnecessarily faking a ground current? He could claim more energy out than in easily without showing that ground current.
This question stays unanswered.
By the way: What things could happen if we connect two different coils of a 3-phase transformer to two different frequencies, like 50 Hz and 100 Hz, phase-locked to each other? Anyone tried? :)
r2fpl
color:
What do you not understand here?
Do you know that by two 0.4mm wires you can move 2kW but at 40khz!
If Kapanadze uses a connection to the ground and says it's important, it must be important. Each device has a ground connection.
Kapanadze, speaking about the bridge, did not talk about the wave coil only! it changes a lot because it talks about grounding.
color
r2fpl:
Can you unveil your yoke transformer?
I want to see your yoke transformer.
