0 Members and 38 Guests are viewing this topic.
color
blueplanet:
Meta:
If you do not acknowledge me giving you information or criticizing the info I give with so flippant an attitude as you have shown, you may very well be intellectually dishonest that I don't want to give you anything, for I know something is very wrong with your approach and you may be using all that I present but only secretly, seeing you are so chummy with well funded clandestine organizations under nondisclosure, and I have no need of that either.
Either way, you need further education about harmonics, world grids, mayan bi symmetry, tzolkine,
I ching, esoterics, scalar, tesla howitzers, unified field, longitudinal energy, radiant energy or overunity, no matter how much equipment you have nor how many people you seminar with.
I do not really know what should I  answer to this.
I by myself.
I'm not interested with Free Energy.
I'm interested deeply with mechanism that is behind devices of Free Energy.
Overunity (OU) does not exist. However term is no longer used as OU but as OU  describing energy transfer that  to the naked eye looks like OU.
In reality   it is unknown to that  very eye, at that very moment what this energy  come from.
I Wesley use  "OU" word to describe in general form of expression subjects related to that Eye  effect of energy consumption  manifestation when there  is no battery not power supply  connected to the device.
Free Energy exists. It is energy that is free of tax. such as  solar energy, water flow energy and so on.
Device of Tariel Kapanadze was legitimate and works  to the naked eye without battery or any other  source of energy .
In reality   laws of thermodynamics specify  very much that even that device must work of the energy that is consuming.
So for me it is important to find what this energy comes from .
Lithuania Experiment with Arunas is  legitimate event.
However mechanism of energy extraction  is  based on different phenomena that Tariel Kapanadze  device.
Will that assumption change?
Possibly  yes.
We have changed our models so many times and world  goes on.
People who are not interested in free generators come to this cafe and people who are interested in free generators are higher-level jokes than intimidating trolls ......  8)
I pray that you are not slave to Wesley.
tysb3
Quote from: color on February 17, 2019, 11:21:08 AM
Good idea. Let's say each of us would be in the size of an ant, then a few milliamps provided by a crystal radio could power a complete ant household. So what's the problem? We have just to make a bigger crystal radio, so it fits our size. :P
no problem, with Tesla's tower
color
tysb3:
no problem with Tesla's tower
The Tesla Tower has no problem,
Why does Wesley claim the Zenneck Wave for the generator ground of Kapanadze, Akula, and Ruslan, which is not directly connected to ground?
https://www.ee.ucl.ac.uk/lcs/previous/LCS2011/LCS1137.pdf
I have no objection to thunderstorms,
https://thumbs.gfycat.com/HospitableTameBongo-size_restricted.gif
Someone seems scared.
color
Then you have to explain how all these atoms that are compressed together to form objects have their electrons all spinning around with orbitals touching other orbitals and we never see objects just fall apart because of electrons crashing into each other. How can  billions and zillions and quintillions of electrons spin around without ramming into each other? So you see the electron flow model is just chock full of holes and areas of reflection that really ask that we all look the other way with regard to these questions. "That's the way it is" is a major basis for understanding electricity in our present days.
https://2.bp.blogspot.com/-GkN3WYHkFqQ/XDZf23Jui3I/AAAAAAAAAxI/kPG1Ms894NUy79gFb-OpHkDfvNgz-nFbwCKgBGAs/s1600/%25ED%2598%25B886.gif
The slowest lightning speed is about 400 km.
color
 wattsup:
@all
OK you guys. Let me just put in an new angle.
If I talk about potential ways to make a device work towards OU, I am not saying at the same time that I believe TK is legitimate. I will never say anything good about anyone flaunting an OU device or a supposed OU device in our faces and in the worlds face while the world is in such dire straights. So whatever I say here from now on is to advance OU, and not the likes of TK or any other Show-and-don't -teller.
So let me open up an idea THAT MAY BE RELEVANT TO THE 2004 TK device. But first you need some background.
As far as all my bench works go with both DC and AC pulsing, the main object of all these techniques is to create a strong polarity change in one coil medium that can impart those changes to a second coil medium with or without a core. As far as what I see on the bench and what is taught in our schools about AC, I know now that we are totally off the mark. AC cannot be a true alternating current if it is to also follow the "electron flow" model of electricity. You cannot have both because of one dead give-away. The AC neutral is always grounded hence it can NEVER be hot. The hot side is HOT, OK, but the neutral is exactly that NEUTRAL. There is never any hot signal leaving from the neutral side to enter the coil(s). Anyone can try and dispute this but if you are honest in your unbiased observations, you will also see this to be true.
DC and AC are really not the same thing at all. AC is not a dual DC even if it is full bridge rectified, just try both methods and try to produce the same sinewaves and you will see there is no way possible (except at high frequencies).
Let's take DC first. I need someone to prove to me that a car battery is 12 volts in that the negative terminal is at zero volts and the positive terminal is at 12 volts as we see today the car battery voltage. So prove to me that the battery is truly 0 and 12 volts and not -6 to +6 volts that would both show a 12 volt potential difference. Prove to me with your volt meter or your scope. If using the scope set it to both DC then AC coupling and convince me which is the valid scope waveform. Why is the DC reading supposed to be considered the valid method?
DC pulse is a simple peak, peak, peak where when the pulse is off, there is nothing to hold it from oscillating. This is useful in some ways but counter productive in other ways because the copper atoms are left to themselves to realign before the next pulse. Nothing can rebias the copper wire before the next pulse.
Now let's look a AC. Explain to me how AC can alternate while there is a ground wire on the neutral side. In the common AC discussion the hot AC signal alternates from the HOT side to the Neutral side and back and forth. So tell me how a hot wire can exist on the same line that is grounded. In general experienced EEers will not even want to take on such a discussion because if their brains are screwed on the same way as anyone else, they will quickly realize this to be the case.
AC pulse is however a very strong gradual rise or better worded "controlled rise" and "controlled fall" where the copper atoms are always under a rise or fall stress leaving no moment for the copper atoms to rebias by any other means. AC is a perpetual controlled peak and rebias but there is never any "electron flow" hence there is not any need for electrons since their reason for existing is to "flow" in a wire. If you remove their reason for existing in this effect, you just killed the electron flow model in one swoop which should have been evident to everyone with a brain way back when Tesla first invented AC. Please try to counter this statement as I would be very curious to know. hahaha
OK, AC then is what? If electrons do not flow, what the hell is going on in our wires? Well to answer this question you have to look at the evidence in front of us. We know the copper wire is made up of copper (and other noble metals) ions or atoms. We are told that all atoms have "electrons spinning" around a center nucleus but we also know that the science behind explaining where these mysterious electrons get their energy to spin around a nucleus is not explained to any fluent degree. Also, those same electrons, since they are on the outer shell of the nucleus, are the only thing humans have every touched so when you grab any object, you are grabbing a bunch of electrons with "floating" nuclei in them. Then you have to explain how all these atoms that are compressed together to form objects have their electrons all spinning around with orbitals touching other orbitals and we never see objects just fall apart because of electrons crashing into each other. How can  billions and zillions and quintillions of electrons spin around without ramming into each other? So you see the electron flow model is just chock full of holes and areas of reflection that really ask that we all look the other way with regard to these questions. "That's the way it is" is a major basis for understanding electricity in our present days.
The worst part of all this is that under this new Spin Conveyance model I will be publishing soon, all of these effects can be PERFECTLY explained while preserving the same method we use today to measure our devices. Only the construct will change. But in a nutshell, if AC is not "electron flow", because all the evidence proves the contrary, then what is it. What's left if the outer atoms shell is to be considered nothing more then a wide variety of bonding mediums, the only thing that's left is the nucleus itself. This is where we have been robbed of the intellectual ability to consider the nucleus as the main causal medium of electric signal throughput. So the answer from there is so simple. All the nuclei have to do is respond directly to outer stimuli or direct applied stimuli. If the nucleus was able to perform what I call the 6S's as being Stay, Show, Sway, Swing, Spin and Shoot and by doing so it can convey these same "physical nucleic motions" to their neighboring atoms, then we have the perfect platform to explain all our effects on our benches which I call Spin Conveyance.
Stay - Leave a coil alone and the nuclei will simply Stay or hold their Latent position. Some will turn and point down to the center of the Earth at their latent position.
Show - Bring a strong magnet and hold it in one place near the coil and the nuclei will show one quick waveform blip then fall to zero hence the blip is the nuclei turning from the latent position to now Show position that points to the magnet source.
Sway - When a magnet wheel passes by a coil, the nuclei will leave the latent position to point to the oncoming magnet, follow it passing in front of it and point to it leaving the coil so its a motion of left/right left/right. This shows movement from the latent position, going left, passing through the latent position again, then going right. So Sway occurs when the nuclei goes from any two left/right positions by passing though the latent position. THIS IS ALSO AC as a GRADUAL back and forth Swaying of the nuclei.
Swing - From the latent position the nuclei goes either left or right then comes back to the latent position. This is DC and the waveform of DC pulses we see shows exactly that. Quick rise then a tapering off and even a negative rebound.
Spin - When you can Swing an atoms nuclei fast enough for it to pass the peak top point and continue in the same direction with perfectly timed pulses, you reach nucleic Spin. Since not all atoms have the physically ideal inter atomic placement inside the copper wire matrix, not all copper atoms can spin. hence those that do are few and we see this with good voltage but crappy amperage.
Shoot - Hit the two terminals of a car battery together and what happens. Sparks start to fly out of the wires. That's Shoot which is not something we run after every day.
When I say Spin, it can also be any of the six above attributes.
The 6S's do more then what is described in this simplified rendition but it is enough to get the idea that if our atomic nuclei was considered to be smarter then we think them to be today, then we just found all the reasons for all our effects, including action at a distance where the nuclei have the ability to sense energy sources from a distance hence not requiring any magical fields to impart their fingers on a wire to "do something magical" to make electron flow in a conductor.
We can then understand that voltage is a function of the degree of spin from the latent position and amperage is simply the number of copper atoms involved in the wire that are spinning. So for the first time ever, you have real physical reasons for our volts/amps effects. You no longer need to believe in these magical electrons and fields. Field collapse at pulse off becomes coil rebias when under DC. AC does not produce the field collapse while running because all it rises and falls are controlled.
AC Hot then becomes nucleic Sway where there is no need to have any electron flow since all that is happening in the wire is the nuclei themselves are Swaying to the applied AC hot. This explains perfectly how AC works in our wires and also explains that only one hot wire is all you really need to do this while the neutral wire is there as an anchoring post. Again very simplified for this post.
So DC is quick rise in the same way and this is why DC is additive. Try and put two AC lines together that are out of phase as all you get is a major havoc since the nuclei are turning left when another is turning right and this creates a major collision inside the wires.
But AC is so great because it controls all the angular movements of the nuclei while DC just spits up and then releases as an uncontrolled rise and rebias making it hard to concentrate a targeted effect.
Of course again the above is a simplified rendition just to give you guys some background to what's coming next.
Sooooooooooooooooooooooo. Is it possible to marry the best attributes of both AC and DC into one method? DC would provide a constant "additive" upswing while AC would provide the controlled rise to keep all of the copper atoms in action. DC is a hit once a hope method while AC is a totally controlled method. But AC can only be applied to a single coil on a transformer where the coil undergoes a controlled rise and fall hence there is no room to play around like with DC. But in both cases, one cannot produce anything analog to the rotation of a magnetic rotor inside of a stator. This we have been  unable to produce since a rotor is a real physical movement that is making the nuclei of each copper atom to physically sway, while AC in a primary has no movement and the sway is always applied at the same vectorals hence the copper atoms cannot follow a physical movement. Same problem applies to DC pulsing as well. In all primary to core to secondary relations, everything has to be accomplished while all are stationary, and this is costing us dearly in our output performance.
So here is the question. hahahaha Always a question hey.
Is it possible to take one AC line and pass it through a type of full bridge rectifier where you can then output TWO DISTINCT outputs that are 180 degrees out of phase? If this is possible, then you can make transformers with two primaries, one left primary, center secondary, one right primary where each primary now gets its own AC peak pulsed that is 180 degrees out of phase and the secondary will now have the impulses coming from two changing vectors. If this can work and increase the intensity of the Sway of copper nuclei, we just made a new toy for working towards OU devices.
Do I need to expand further. Guys in the know will read between the lines.  hehehe
wattsup
Someone insists on the US Army and the strange debate rotates the brain of innocent lambs.
