0 Members and 55 Guests are viewing this topic.
TEKTRON
Quote from: hartiberlin on July 04, 2013, 09:47:30 PM
Hi All,
I just posted this summary slideshow video of the last postings from this thread over here
with some new speech synthesis software I am testing...
Do you like it this way ?
https://www.youtube.com/watch?v=Q-P9ygH6T20
Maybe I will do this much more often when I got some free time and thus
post the latest updates this way...
Or is this too annoying to watch ?
Please let me know and comment under the video on youtube.
And please give me a Like or Thumbs down...
Many thanks.
Regards, Stefan.
Stefan, I like it. I am dyslexic and reading is more than a chore for me. It is nice to watch the vid and listen to the syn to verify what I have read. Please keep doing it! Thanks, John
Grumage
Good evening all.
Well I just felt I had to post some news. I now have my device so close to unity or even, may I say it, dare I?? The thing is I do not know for sure. Or it's a very elaborate light switch :)
Around the 27 KHz area I have two 60 W incadescent lamps at 4.5 on my "Watt box".  Number 5 being 60 W. Total input watts 81. This being measured by a commercialy made plug in unit.
BTW I have also confirmed with 50 Hz Ammeter and Voltmeter, as the input supply is running at 50Hz.
I have some very nice resonations going on within the center choke. I can see these because I have made a Tesla style 10 turn coil sat at the base of the choke coil.
Now for the weirdies.... For some reason after my device has stood idle for 24 hours or so. Initial switch on gives a result. Switch off and then on again and you get a completely different set of waveforms than before??  Earlier on this evening after making some adjustments I found higher frequencies were giving a good output but coming back down towards where I had been earlier, the input current got so great that I had to switch off the drive signal. I then had to reduce my input volts by half and try the 27 KHz frequency again. Current noted, Ok, then I could apply the full 90 VDC again!!
I dont know whether you, dear Verpies, could shed some light on those anomalies? Possible magnetic saturation of the Ferrite transformer core?
If time permits I will try and make a short video of the setup and provide the very important scope shots. And yes, I will tell you from where they are taken!!
Cheers and Nos Da. Grum.
MenofFather
MenofFather
If akula not use LC series resonance (or not use capasitor, who in picture), then voltage be like in this picture, not rise on coil and capasitor.
Если бы Акула не подогнал колебательный последовательный контур бы в резонанс, то напряжение было бы везде одинаковое и что с конденсатором, что без конденсатора. Он в предыдущих видео говорил, что резонанс определяет по наивысшему напряжнию на конденсаторе или что-то в этом роде. При резонансе в последовательном колебательном контуре выростает напряжение, добавляя нагрузку она упадёт, но так как там первичная обмотка не на всю вторичную, где лампочки подключены, то полностью резонанс не разрушаеться.
Grumage
Good evening all.
I have spent the best part of two hours preparing a video for you all only to find that the HF generated by the setup froze the cameras video side. The short?? video turned out to be 17 mins long but I cannot upload it because the save and convert process stops at the bad bit!!
I will have another go tomorrow. Any ideas on how to stop the camera from being affected? I was trying to get closeups of the Oscilloscope shots.
Cheers to all Grum.
