0 Members and 119 Guests are viewing this topic.
AlienGrey
Quote from: T-1000 on March 05, 2019, 08:19:40 AM
NickZ,
The akula's controllable katcher with 100-150V on Tesla coil primary was used in latest Geo videos. The only critical point there is voltage divider on transistor base which is limiting max voltage to safe range.
So it doesn't go in smoke.
Obviously we need quite range of HV depending on earth/air conditions for ionisation. Without it there will be no effect.
And the positive high voltage need to be on grenade so circuits showing direct ground connection from it are killing voltage.
Cheers!
yes ! if you include a very small value resistor in the MOS-fet sauce the voltage will increase with the load
if a buffer transistor is included and fed back into the 8pin driver chip pin 3 then a form of protection could be included.
Nick the Sergey circuit uses an onboard 1.5 MHz OSC it doesn't suffer from such problems as microphonic transients
blowing the output transistor into oblivion.
Also, one of Adrian's photo's shows a metallic copper clad board under his grenade supposedly for collecting ions.
NickZ
   T:    So, you take 150v from the grenade to the Kacher input, then need to lower that voltage. What is the point?One of the cheap AC to DC converters or DC to DC units, can reduce and control the input voltage to the Kacher circuit, once it is rectified from the 28 t coil, or from the batteries, to any voltage needed. Which is what is shown on Ruslan's video. As it can not really handle 150v, even close to it.  I have burnt Kacher circuit components by providing only 30 to 40 volts, as it's not design to handle that much juice, unless it's further modified. Nor is that much voltage really needed, according to Ruslan.    Ruslan, Stalker and Adrian, have shown self runners running from 12v circuits, and able to produce the needed effect on the grenade. So, is that not enough to start with, to ionize the air?
   You have not mentioned what happened with the simpler Akula suggestion to use a spark gap circuit, instead.
So, did you do that, and if so what did you find?
   I could never get 150v from my grenade's output, with a full load of 400w to 600w bulbs, after being rectified by the full bridge, but only less than about 60 to 80v, instead.
   I agree that the earth ground when connected to the wrong place can kill the output.  But, I don't know if the air is really needing to be ionized, as there is good output and clean sine waves from the Kacher running on just a 24v input. And Akula, Ruslan and others have shown that even the 12v circuits could be made to self run. IF true.
   What is the point of ionizing the air, and spewing smelly ozone like an old TV in bad shape?
T-1000
NickZ,
The akula variant had variable voltage from secondary winding on yoke. Which was rectified and fed to Tesla primary coil. Definitely not 12 or 24 volts there. Again, for higher Tesla coil output voltage there are only 2 options. Make secondary coil longer and lower frequency plus add delay when you want chop off sine on peak or raise primary coil voltage to keep it responsive to same spec we are doing with nanosecond pulse in Dally or latest Ruslan circuits.
So that is up to you... ;)
Cheers!
NickZ
  We don't know the actual voltages used by Akula provided by the grenade output to the input to the kacher's input. What we can see it a small 3mm sparks at the ferrite rod. Probably not even as high an output as what I see using 24v input to my Kacher circuit.  I also don't see any ionization, or even much of a streamer coming off of the antenna coil on Akula's second device, or self arcing.
  The purpose of the kacher is to disrupt, and is not additive to the voltage at the grenade's output.
So, how much juice is enough to provide for this disruption, and what can be considered excessive, or too much?
Hoppy
Quote from: NickZ on March 05, 2019, 01:37:45 PM
Good questions Nick! However, I doubt that anyone on this thread can answer those questions with confidence based on the experience of having achieved the building of a true self-running device.
