0 Members and 177 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on March 06, 2019, 09:26:05 AM
   Soliman:   There is nothing unusual about the 2 second delay after turning off the Kacher, it is due to the big black DC cap at the rectifier, which takes a little while to drain. The newer rectifier that I use now does not do that, as it's different caps don't have the same storage capacity. But, it allow for a higher total output, than the older rectifier system.
   Geo:   Thanks for your comments.    What I see in the video that you posted a link to, looks like there is still very low output from the 300w bulb. So, I don't see the advantage, unless it allows the device to be able to self run. Which up to this date has not been shown, no matter how the wiring system is connected up. As the main thing is self running, not the different ways that the circuits can be wired up.   I had an adjustable DC to DC converter up to 55v, but I blew it up connecting it backward in polarity. And could not get it fixed as the main chip that blew is not to be found here. So, I may have to order a new board.
   Listen to the Ruslan video where he shorts his 0.47uf WIMA capacitor. You can hear the difference in the intensity of the spark. Big Bang. I have not been able to get that kind of response, but I only use a single WIMA cap, not two of them as is shown in some videos. That shows the amps that are running though his whole device. 8 to 10 amps or so, output. Not the input drawn.
  So, how is your system now. Is it operational?
Nick Z it sounds like you haven't tuned what you are calling your 0.47 cap as it's value or size depends on the
properties of your push-pull 'yoke'  and winding 'read Wesley's' publication on setting up!  please RTFM (read the frigging Manuel) and there are two of his circuits as you might get better results with a cap across the windings as in colors film it won't tune itself you have to do it your self. I made 3 test windings and they are all different with totally different values the mos fets are huge cap switches.
Nick another thing is where you live when you pull the bath plug which way does the water go down the plug hole ?
you might think it's trivial but it's important.
NickZ
   AG:   I'm not trying to invent a new way of doing things, just trying to replicate the schematics. Don't you think that after two years of playing with the device that I have not tuned it to the best that I can? My induction circuit, yoke, and windings are as the diagrams states. The wima caps are very expensive, I think that I paid about $35 or so for just one. However, my 0.1uf wima cap on the grenade output was not able to handle the output and has cracked from the heat, although it still works. Yet, I do have other caps to play with. I could use some new wima caps though. But, I have used other caps to test with, similar to how Geo uses his older 0.33uf caps to tune with. Of course the wima caps work better.
AlienGrey
.47 2000v that's a lot of money, I bought a job lot 20 off  0.22 , 0.15 , .010  plus a pile of other values from a closing down company it wasn't too difficult finding resonance with a scope and an SG and finding correct value to boost the effect.
AlienGrey
Quote from: Hoppy on March 06, 2019, 02:10:32 PM
Only £4.82 each from Mouser Electronics.  :)
https://www.mouser.co.uk/Search/Refine?Keyword=WIMA+MKS-4&Ns=ManufacturerPartNumber%7C1
Ha ha! they havent got any !  ;D ;D ;D ;D
Anyway, have you built a yoke device have you worked out the frequency your using ? have you found the actual inductance XL and found XC ? for the same frequency what value do you get? mine works out to 0.357Mf 0.470 is a bit big and I would be off tune  ;D 8) 8)
