0 Members and 74 Guests are viewing this topic.
AlienGrey
Quote from: seychelles on March 08, 2019, 12:11:08 PM
I WISH TO GOD SOME SMART TECH OUT THERE WILL BLOKE DIAGRAM THIS CIRCUIT,
OR IDEA, SO THAT WE CAN COMPREHEND WHAT WE ARE AIMING FOR..YES THERE IS
A VERY HIGH VOLTAGE AC SOURCE THAT IS CALL THE KACHER FED VIA A COUNTER
WOUND COIL, I ASSUME IT LIKE AN AC DIODE,,MEEEH.
I WISH TO 'Yahweh' SOME SMART TECH OUT THERE WILL BLOcK DIAGRAM THIS CIRCUIT.
which way does water go down the drain where you are?
AlienGrey
Quote from: Tomtech29 on March 08, 2019, 12:30:14 PM
Hi.
How do you go about establishing this form of standing wave moved 180 degrees ,You are the studies on the Pll looping system "LC"
-inductor circuit it should not have any interference from high frequency what driver you are currently dealing with how you resolved to keep the resonance in place?
I used some cmos logic and it's not 180  add the 1&8 you might get somewhere then 2 D types with some phase manipulation of R S D inputs.
But you dont need that in the above circuit as the above Sergey circuit lets you move in time so the wave can start when you like ie 90 deg but the Katcher and push-pull need to be frequency locked depending on the 37.5 m and the 40 m versions to my way of thinking.
Tomtech29
Quote from: AlienGrey on March 08, 2019, 12:41:59 PM
So thanks already introduced the correction ,I listened to something (push-pull need to be frequency locked). it is a conditional conditio -in my experience it was that I've fallen over this system I did not have a good example to grow up scope of activity and learning ,what it looks like now (or in your case when the coil warms up) you have this work under control?
what is it based on you can give the secrets?
AlienGrey
well division from a master  clock could be one way to track a 90 phase would be to use a 1/4 wave of the final frequency
which is how it's done in a microchip ie 4mhz to produce a 1mhz as 4mhz would appear 4 times as in Wesley's circuits.
You would have to use a phase lock loop in your design to pull the frequency of the VFO back into lock I would assume.
But why not use low drift high-quality components capacitors from cheap suppliers can be a problem as they can heat up
and drift and even destroy expensive components.
apecore
Hi Guys,
I m still on board,.....or better still of the street.
More or less it becomes a piece to put on the wall in the livingroom,... ;)
Greetings
