0 Members and 47 Guests are viewing this topic.
AlienGrey
A nice big picture I can see you have made a capacitor switch but if you need analysis as to why it doesn't
work then you need to do your homework on your tuned circuits.
Void
Quote from: Jeg on March 08, 2019, 11:24:59 AM
Did you see the device published in Wesley's thread? Impressive looking at it.
Hi Jeg, If you mean the video demo by starlight on Youtube, it looks to me to be based on
a similar idea to Tesla's 'Method of Utilizing of Radiant Energy' (patent # 685958).
The air is known to have an electric charge. If you use a large metal conductor suspended
in the air, such as a large metal roof, it can probably collect a significant charge from the air.
It takes time to charge up the storage capacitor in that circuit, so he is getting a low frequency
discharge rate through the sparkgap, and then through the bulb. This would appear then to have
nothing to do with Schumann resonances, from what I can see. Maybe you were referring to a different
circuit that Wesley has posted however. :)
Jeg
Hi Void.
Yes we are talking about the same video. The difference in potential between antenna and ground is not enough by ityself to produce 28Hz discharges over the bulb. His coil system looks responsible for that and looks like the same idea as with Kapa and the others. To be honest, if i had an alive spark gap like that even without any load attached i would staring at it all day long. ;D
Jeg
Quote from: apecore on March 08, 2019, 01:52:52 PM
Hi Guys,
I m still on board,....
Nice to see you again. Sometimes we need an off of everything in order to clear our minds. It is normal before getting in to shit again.
In addition, we all here have the same decorative ideas... :D
Guys, i really wonder. How the heck someone consums just 600uA when using a Kacher? Has anyone ever made a kacher spending so little energy across his input?
Sergh
 ;D
It is not KT205, it is KT805 transistor.  These transistors are often used in devices like "Katcher".
https://www.youtube.com/results?search_query=Katcher+KT805
A feature of transistors is the relatively high maximum frequency for this type.
They were widespread in Soviet times.
30 years ago it was used frequently in audio power amplifiers or in automation systems.
Polarity          NPN
Рc max, W     30
Ucb max, V    300
Uce max, V    135
Ueb max, V    5
Ic max, А       5
h21е              >15
Uce sat, V      1
Ft, МHz          20
Package         TO-220AB
http://www.transistor.by/en/products/exported/transistors/bipolar/Bipolartransistor/?curPos=180
