0 Members and 417 Guests are viewing this topic.
Jeg
Hi Nick.
Too many open projects all together as usual :D
About what I said for katcher's operation is just my experience with it. Nothing more.
It is just for optimum performance but nothing to worry about in relation with the successfulness of Ruslan's replica. Even with the right cap there my device is still UU. (stands for UnderUnity systems)
Hoppy
Quote from: AlienGrey on March 10, 2019, 11:15:24 AM
......Adrian's didn't work like that nor did Ruslan's
it needs to be hooked into the switching time of the yoke at the right time, not random.
Correct IMO.
Void
Quote from: Jeg on March 10, 2019, 04:54:20 AM
Hi Void.
Yes we are talking about the same video. The difference in potential between antenna and ground is not enough by ityself to produce 28Hz discharges over the bulb. His coil system looks responsible for that and looks like the same idea as with Kapa and the others. To be honest, if i had an alive spark gap like that even without any load attached i would staring at it all day long. ;D
Hi Jeg, maybe, but we don't know exactly what he is doing, so that is only an
assumption on your part. If he is using a metal roof and say has a cell tower very near by,
that could possibly account for it. A large metal roof can probably collect quite a bit of charge
under the right conditions at any rate. :)
Sergh
Not everyone here understands what "Kacher Brovin" is.
No drivers. Only 1 transistor and 2 coils and power supply. The power supply can be very low voltage, less than 1 volt.
"In 2000, Brovin developed a new" proximity switch "sensor - a device that allows an arbitrary metal or metallized
electrically insulated surface to create a volume charge of an electric field. A foreign object entering this field from outside
causes the relay inside the device to trigger and any information circuit (sound or light alarm, radio transmitter, pager, tape recorder, video camera, etc.).
When changing the bias in the base, the continuous generation process was converted into an intermittent,
in the form of bursts of pulses. In 1988, I found that the signals that I took to block the process are short needle-shaped pulses of tens of nanoseconds.
I doubted the existence of mutual induction between the base and collector inductances, and I could no longer call such a scheme a blocking generator.Continuing to study the properties of the obtained circuit and those close to it, in 1990 I found that it works
without a core. It turned out that such a generator can be made both on known and on "improbable" circuits
with one or more inductances connected to any electrodes of the transistor, with mutual induction providing
feedback both positive and negative. The generator works without feedback. The collector with the emitter can be
interchanged, the generation does not stop, only the waveforms change.
Generator frequencies can range from fractions of a hertz to hundreds of kilohertz.
These results can be achieved by selecting the number of turns in the inductances. "
Patents Brovin:.
1. RU2013151625 TRANSFORMER TECHNIQUE FOR TRANSISTOR CONTROL
2. RU2444124 GENERATOR OF ELECTRIC KACHER CIRCUIT BREAKS ON TRANSISTOR
3. RU2265276 NEW METHOD FOR TRANSISTOR CONTROL-
Void
That's interesting about that different variation of the 'kacher' circuit, Sergh. Good info!
