0 Members and 43 Guests are viewing this topic.
Sergh
Quote from: AlienGrey on March 13, 2019, 10:39:57 AM
Now, what have we here they are harmonic energy spikes of a device that obviously does what your saying it is impossible!
I see  voltage with a noise spectrum. Unable to estimate energy. To estimate the energy, you need to know all the instantaneous voltages and currents through the load. Then integrate it all over time. These are non-sinusoidal voltages; you cannot use a voltmeter, an ammeter, or a wattmeter used by mustached Electrician.
Only a special chip that can integrate everything in real time can handle energy counting. But at high frequencies and the chip will not cope. It is necessary to transfer this noise signal to a non-inductive load, place the non-inductive load in a thermos with water, and measure the difference in water temperature over a period of time. In the last century, the waveform of the pulse signal was printed on paper, the signal was cut out with scissors, and the cut out paper was weighed to estimate the pulse energy approximately.
There is another kind of problem. How to absorb the energy released in a pulse? There are different impulses in your signal. Different types of pulses have different load capacity - the impedance of their source. If all pulses are 50 ohms, this is wrong. Some pulses are low, but powerful, they need 20 ohms. Some are tall, but weak, they need 500 ohms. Otherwise, the energy will not go from the source to the receiver....erased another as not relevant..
forest
HF diode bridge ? diode bridge + capacitor ? modulate on ferrite core to 50hz then apply low pass filter ?
AlienGrey
Thanks, Surgh for the spectrum analyzer reading lesson, unfortunately, it's not my analyzer >:(
THE EXCERPT was taken from Sergey's video https://www.youtube.com/watch?v=i6agvT27UP8
However, the display doesn't prove free energy doesn't IN THIS INSTANT but there again no Earth
is being used and should not be used as is being used by the naysayer fraternity here as we know
it does it is simply to show you that HARMONICS DO EXIST.
Sergh
High frequency diodes have low efficiency and large losses at equivalent noise spectrum above megahertz.
There is a special POWER HF  arsenide-gallium diodes, but such diodes are not sold on the market, or are very expensive.
In addition, it is necessary to match the source and load impedances. Usually this makes a special transformer.
Probably a suitable chip for measuring energy of chaotic pulses, but not high frequency:https://www.analog.com/media/en/technical-documentation/data-sheets/2947fa.pdf
AlienGrey
Quote from: Sergh on March 14, 2019, 03:47:13 AM
As with all modulated signal frequency RF needs demodulating down to a more usable frequency by heterodyning !!
only a reprobate/novice would try rectifying or using UHF RF as is as a power sauce directly and ignore phase shifting etc.
As I'm sure it's a puzzle where Mr. Henry T  Morey and others like D Smith obtained his devices you refer to from.
