0 Members and 64 Guests are viewing this topic.
NickZ
    AG:  Ya well.... That's what you always seam to think. That these matched frequencies are going to line up perfectly. They don't.
    Can you produce something out of all those good thoughts and ideas that you've read about, that you think is the way to go, but haven't shown anything actually working? So, why don't you try to match those frequencies as you think should be, and show us how well it goes.
     What I'm suggesting has been tested, already, concerning the diodes in the previous post. And, I know what I need to do as a next step in the process.
     No need for armchair suggestions that have not been tried, first. But, thanks anyway.
   BTW: My Kacher has no problem running at 1.5MHz, but it works BEST at around 1MHz, as far as what it does to the induction circuit and it's coils, which can be seen at the output of the bulbs.
conico
A G. , an advice on the Russian forums, uses only the harmonics multiples of 3, that is 30th, 60th, 90th, in your case may be 90th.
I have two more pictures taken from the forums, I do not remember which forum,
these pictures reveal the secret of how to tune Ruslan devices.
I found these pictures yesterday on my computer but they were two years old.
conico
A.G, There is nothing wrong with Sergey's movie.
In the first part of the film, he sees that his spectrum analyzer says something is wrong, Sergey saw that and at 9.47 in the movie he saw that, he had changed his tesla coil secondary. After that he didn't use Sp Analyzer.
An information on Sergey movie is his secondary tesla coil is 37.5 m long wire, 1 mm diameter.
AlienGrey
Quote from: conico on March 16, 2019, 02:16:40 AM
In the first part of the film, he sees that his spectrum analyzer says something is wrong, Sergey saw that and at 9.47 in the movie, he saw that he had changed his Tesla coil secondary. After that, he didn't use Sp Analyzer.
Information on Sergey movie is his secondary tesla coil is 37.5 m long wire, 1 mm diameter.
Hi there Conico I didn't say there was, did I? the only problems I have has so far is one of the other circuits
where the 1.5mhz Nand gate is fed into the buffer UCC37322 it loads it and I get nothing luckily though there is a spare buffer
I used and changed the UCC37322 to a 37321.
Another problem I had while testing was locking the 1.5Mhz to the 15khz signal but after a lot of trouble building some logic
I found the Scope a Rigel DS1054 is not too accurate on frequency so be aware.
I too had to rewind my Katcher to match up wire length lambda for resonance matching in order to get peek amplitude at 1.5 and 15khz! on my test rig.
Sergh
Quote from: NickZ on March 15, 2019, 09:43:52 PM
Very simple, like "Kacher", circuit for a higher frequency. ;D
In the circuit used a special radio frequency, but cheap transistor.
https://www.youtube.com/watch?v=BGgIrkNfa7U
On YouTube you can find a lot of similar instructions for building such a "Kacher" .
