0 Members and 423 Guests are viewing this topic.
conico
Quote from: NickZ on March 16, 2019, 06:50:33 PM
   conico:  I am using a 0.1uf at the grenade output coil for parallel resonance. Ruslan uses 2, 0.15uf.
   As these wima caps can get hot, mine cracked, and other cheaper caps that were not the wima caps can burn up, as there is a bit of current there.
   I also use a couple of the black AC fan caps about 3uf each to filter with, after my full bridge rectifier, but before the bulbs, also.
   What voltage do you have now at your bulbs?
NickZ,
I do not know where to put the resonant capacitor on the Grenade Coil  terminals or after 28 Turns?
in my case 100nF does not fit anywhere for 15Khz.
http://www.pronine.ca/lcf.htm
Void
Guys, I think there is probably no cookie cutter solution for these type of devices.
There are so many variables from one setup to another. For example, exactly how you
are taking your output off the grenade coil, exactly what you have connected as a load, etc, will give you
different impedances, which can also significantly affect reonanant frequencies and that sort of thing.
Also, the quality of your earth ground connection, and the length of your ground wire, and possibly even
the wire gauge of your ground wire could possibly also make a difference with what kind of results you are seeing.
Akula and Ruslan seemed to have used fairly long ground wires, if you include the fact
that Ruslan seemed to be in an apartment and not on the ground floor in several of his demos. That might be a factor
as well. At least some of this might well be why different people are seeing different results and different waveforms,
and different degrees of 'effect' when connecting in the ground wire. Just my two cent's worth on that for today. :)
On another note, Wesley really seems to have gone off the deep end for the last year or so.
Frequently implying that people who disagree with him or who spam his thread with off topic stuff
are 'paid Russian trolls' or 'Russian spies', and really seeming to believe that two incidents where
he got really sick were Russians trying to bump him off, although it seems to me that food poisoning
and just coming down with a bad flu are quite reasonable explanations for what happened to him. For Wesley
to ignore the more plausible explanations and keep insisting the much less likely scenarios are what happened
appears to show a serious disconnect from reality there. Now Wesley has taken to taunting other forum members
here in his thread, implying he has 'free energy', when he has demonstrated nothing of the kind that I have seen,
and his hypothesis he has been putting forward seems to be completely disjointed and missing key connecting
components, and really just does not seem to make much sense overall when you compare to what Kapanadze was doing.
I have suggested this to Wesley in the past, but I think Wesley maybe needs to take a break from this whole free energy
scene for a while and just work on getting his head together. At any rate, it is all par for the course for ou.com.  ;D
NickZ
   Jeg:   The video below was made some time ago, but it shows what happens when a simple Kacher is connect to the grenade, but the induction circuit is OFF. Maybe something similar to what you might be working on, in your version of Roma's device.   https://youtu.be/mpS7noQZ7DQ.
    conico: The 0.1uf wima cap goes at the output ends of the grenade coil, in parallel, before the full bridge recitifier, and before the bulbs. You can try out different value caps to see what works best for your set up. Ruslan shows a 10uf cap there on some diagrams.And one or two of the 0.1uf or 0.15uf on other diagrams. So, play around with it a bit, but try to use the highest voltage value WIMA caps. Or expect some heating issues there.    Like Void mentioned, there are several different grenade connection methods, so you'll have to see which one works best for you. My system uses the original TopRuslan 7 design, but with a full bridge rectifier, instead of just two diodes. Something like the diagrams posted by Ruslan, below.
Sergh
That's right, the world is strong in diversity. If everyone make circuitry from information Akula or Dalli, there will be no diversity. Everyone will do what their idol told them. Everyone does the same thing. Disaster. No chances.
There is no sinn to waiting for the free energy messiah.
We must do each in its own way.
It is a mistake to develop a scheme without knowing the principle.
First, need to come up with a principle that can give free energy. And then we make a scheme for it. But not vice versa.
The principle may be quite unusual. But logic must be present.  Basic physical principles and laws should not be violated. If you presume a violation of some physical law, this assumption must be proved.
Void
Guys, I guess a simple circuit reality check test, whatever specific circuit arrangement you are trying,
and regardless of whatever waveshapes or frequencies you are using and seeing on your scope,
is do you see a marked increase in available output power when connecting your earth ground wire without
a corresponding increase in input power to your setup? If you are only seeing a relatively small or no difference
when connecting your earth ground wire, then it would appear that something is quite wrong somewhere. In that recent video
where 'DragonLord' or whatever his name is visits Ruslan, and Ruslan does a demo for him, I recall the device shut
down immediately when Ruslan discoonnected the ground wire, showing that the ground has a major effect in Ruslan's setup.
